Results 1 to 10 of 16
Thread: My Super Pump has died; what should I get?
    Jun 2014
    Florida
    Default Re: hello
    I have been reading about a lot of single speed pumps as well. It seems as thought all of the manufactures are saying that they have increased the efficiency of their single speed pumps as well. Is this just lip service or are they on the same level of energy usage as my old super 2?
    Default Re: hello
    Quote Originally Posted by bry14661 View Post
    I haven't seen that, but since they haven't changed the 'wet ends' the only change that they can make is in motor efficiency. Changing that isn't going to produce a visible improvement in your electric bill.
    Nothing they can do with motor efficiency approaches what's already been done with motor speed: on low speed, a pump ALREADY moves 1/2 as much water for about 1/6 the electricity (300% efficiency increase). With a VS pump, you get BOTH the very large efficiency improvement from speed changes and the maximum efficiency improvement from motor changes. (A VS pump motor is the MOST efficient electric motor you can currently get on a pump).
  1. My Pump Just Died
    By onemsmom in forum Pool Equipment & Operations
    Last Post: 04-17-2012, 07:21 PM
  2. Hayward Super Pump is Super Noisy
    By moneypitpool in forum In-Ground Pool Construction and Repair
    Last Post: 07-25-2011, 10:16 AM
  3. Pump died, need a new one
    By jmac31 in forum Pool Equipment & Operations
    Last Post: 06-20-2011, 01:31 PM
  4. Hayward Super Pump - Super Hot and Shutting Off
    By CapitalBoo in forum Pool Equipment & Operations
    Last Post: 06-18-2011, 09:32 AM
  5. Pump Died? Help with Autopsy
    By CoffeeBean in forum Pool Equipment & Operations
    Last Post: 06-25-2006, 06:26 PM
