Results 1 to 10 of 23
Thread: Low pH, Hardness, Alk, where do I start?
    BigDave's Avatar
    Default Re: Low pH, Hardness, Alk, where do I start?
    Can you remove / disconnect the copper ionizer unit on the SWCG so you won't add more copper to the pool?
    Jul 2013
    Oregon
    I saw this mentioned somewhere else, but no instructions were given.
    So I just tested again, and the pool still has chlorine in it. Does that seem odd? I went ahead and added more bleach. No one is swimming this weekend because the weather is too cool and the water temp has dropped.
    16'x48" Intex, 5061 gallons, Intex 1500gph filter, Intex SWCG #54601EG, Filling with water on 6/7/14.
  1. Sand filter changed @ start of season ? HIGH PRESSURE @24 PSI FROM START
    By timmygreene in forum Pool Equipment & Operations
    Last Post: 05-21-2010, 07:48 AM
  2. zero hardness
    By poolgal in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-01-2008, 02:54 AM
  3. Hardness
    By Lil Bit in forum Dealing with Alkalinity and Calcium
    Last Post: 08-16-2006, 10:25 AM
  4. Hardness
    By Lil Bit in forum Pool Chemicals & Pool Water Problems
  5. Hardness
    By Sunny32504 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-25-2006, 11:43 PM
