Results 1 to 10 of 11
Thread: Trying to clean up pool-swamp; Pentair DE filter stops up almost instantly
Threaded View
  1. #3
    May 2014
    Default Re: Trying to clean up pool-swamp; filter stops up almost instantly
    I have a test kit. I also have got 90% of the debris out. . The pool turn from a swamp to a light green but like in said even after cleaning out the filter adding new de it sint run very long without pressure rising. I'm soaking the grids right now to see if that helps. As to my pool it's a liner emerson 1hp pump. Pentair fns plus 48sq ft filter. And 20x40
    Sounds like you may be trying to filter live algae with a DE filter. That will not work -- live algae stops up DE almost instantly.
    1. Get a OTO/phenol red test kit, locally (Walmart, Kmart, Lowes, etc.)
    2. If you haven't already done so, remove all the physical debris (leaves, branches, etc.) from the pool. There's no point in trying clean it up till that's done.
    3. Describe your pool: concrete/vinyl/FG; pump make/model; filter make/model, pool dimensions.
    20x40 IG vinyl pool; 1HP pump; Pentair FNS+ 48sft DE filter; PF=> 4 ?
  1. Pool filter cartridges. How to clean
    By RTonk in forum Pool Equipment & Operations
    Last Post: 03-05-2014, 10:45 AM
  2. Trying to clean a green swamp
    By Bowlin1969 in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-21-2013, 06:34 PM
  3. When to clean the cartridge filter?
    By csevel in forum Above-Ground Pool Construction & Repair
    Last Post: 06-28-2006, 11:35 AM
  4. Pool Rover Plus stops often
    By DMand in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-01-2006, 08:10 PM
  5. How to clean the cartridge filter?
    By west1745 in forum Pool Equipment & Operations
    Last Post: 04-23-2006, 04:31 PM
