I stopped the draining at 2 feet, grabbed the water hose and a brush, and cleaned off all the algae I could from the pool sides. Once the debris settles, will remove as much from the bottom as I can using the vacuum head and gravity feed on the water (shouldn't remove more than an inch or two more.)
When all of this started, I put AquaChem Algae Eliminator Max in the water, with 2 pounds of Shock PLUS. After that, I added 1/2 a bottle of Sink & Sweep. When the flocculant didn't appear to work, I took a sample in to the local pool store, who said I ad high phosphates, and sold me a bottle of phosphate remover, and said to put 5 bags of Shock PLUS in the pool with the PhosFREE, then run for 7 days backwashing every other day. All this did was make the pool more cloudy, and eventually, the algae came back.
I'll start refilling tonight, and once I can run the pump again, will begin the recommended 1 1/2 gallon of bleach treatment. Once I get the algae in check, is there any particular order I should add chemicals, i.e., Borax & Muriatic Acid, Stabilizer, Baking Soda?
Thank you both for the help, it is most certainly appreciated!
