Sorry it's taken me so long to reply. I was been running a fever with a fairly bad headache and severe fatigue and joint pains from Saturday till Thursday AM early . . . and pretty mentally destroyed as well. Turns out I probably either have an acute Lymes infection, or West Nile. Since antibiotics appear to be helping, it's probably Lymes.
I'm still tired, but hopefully my IQ is back into the 3 digit range!
(Did you know that you could be bitten by a nymph-stage deer tick -- about this size => . <= when fully engorged, and ready to drop off -- and never even notice the bite, but still be infected? Yep!)
Anyhow, back to your CYA level.
=> When you mix R0013 to your pool water and the sample remains CLEAR, you have ZERO or very low CYA
=> When you mix R0013 to your pool water and the sample becomes so cloudy that the black dot is obscured BEFORE you reach the 100, your CYA level is MORE than 100 ppm.
So . . . mix 1/2 cup of POOL water with 1 cup of TAP water. Use that mixture for your CYA test, and re-run the test. Multiple the result by THREE (3), and that will be your approximate CYA level.
AND . . . do not worry about your alkalinity level -- it's not a problem on a vinyl pool with a CH=100
