Help
Remember Me?
Forum
FAQ
Calendar
Forum Actions
Mark Forums Read
Quick Links
View Forum Leaders
What's New?
Advanced Search
Forum
dichlor (a sunlight stabilized form of chlorine)
FAQ
register
Results 1 to 10 of 14
Thread:
Thread Tools
Show Printable Version
Email this Page…
Subscribe to this Thread…
Display
Switch to Linear Mode
Switch to Hybrid Mode
Threaded Mode
Threaded View
09-09-2012
05:01 PM
#7
PoolDoc
View Profile
View Forum Posts
Administrator
Quark Inspector
Re: dichlor (a sunlight stabilized form of chlorine)
4% is fine; just add 1.5x as much.
Is 4% the more common strength in Canada?
Quick Navigation
Top
Site Areas
Settings
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
Forums
Ben's Corner
Forum Q & A
-- Subscriber Posts --
Dealing with Algae & Slime
DPD-FAS based testing
Pool Equipment & Operations
Pool Electronics
Odds-n-Ends (P)
Photo Gallery
Clearance
--cleanup--
The China Shop
General Interest
Practice Forum
PoolSolution Archive
The Hall of Shame
No chlorine registering
Pool Closing Headache
Chlorine stabilized, pool not green, what's next.
By keastman in forum Testing and Adjusting Pool Water Chemistry
5
Last Post:
04-09-2012,
07:08 PM
Does pH change when covered/with lack of sunlight?
By elsie in forum Testing and Adjusting Pool Water Chemistry
6
Last Post:
08-27-2010,
04:30 PM
non stabilized chlorine
By nisqu in forum Using Chlorine and Chlorinating Chemicals
5
Last Post:
06-09-2008,
07:03 PM
Does local Govt participate in spreading the stabilized chlorine deceit?
By Water_man in forum The China Shop
13
Last Post:
06-08-2008,
09:03 PM
HTH Non-stabilized chlorine tablets
By vanhout in forum Using Chlorine and Chlorinating Chemicals
13
Last Post:
07-03-2006,
10:42 AM
Digg
del.icio.us
StumbleUpon
Google
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
