Results 1 to 10 of 12
Thread: Is there BBB method of closing?
    Default Re: Is there BBB method of closing?
    Just make sure that you have the pump running during anytime that the water in the piping might freeze, so you don't have burst pipes. My pool is completing its 11th season, and it's never been closed for the winter
    jwhouse is offline Registered+ Thread Analyst jwhouse 0
    Jun 2012
    Southeast Louisiana
    Yeah, I got that! Ice and pool equipment bad! Cold weather and moving water OK! LOL! That doesn't happen very often and for very long periods down here though. You guys actually get colder weather than we do. I am originally from the Texarkana area and it used to sleet and ice over every winter there and even a lot in the Shreveport area while I was at Barksdale but I've seen something like that happen here maybe twice in the 16 years we've lived here. Actually still have a house close to Springhill on Lake Earling so we get up that way every year to keep pipes from freezing.
    30' round 22K gal AG vinyl pool; skimmer tabs and GV Bleach; Hayward SD60 sand filter; Pentair 1.5 HP pump; hrs; ; utility water; summer: none; winter: none; K-2006 Test Kit ; PF:5.5
    Apr 2012
    Texas
    In East Tx here, and also considering leaving the pool "open" for the winter! Do you run the pump and filter every night, or only when weather is freezing? I guess the only maintenance would be really to net out leaves and add bleach every now and then?
    18' round 7.5K gal AG vinyl pool; bleach; Hayward C900 cartridge filter; Hayward Power Flo Matrix 3/4HP pump; hrs; HTH 6-way test kit
    ; community; PF:16
    Personally, I only run the pump/filter overnight on nights when the weather is below 30 degrees. I do try to run it a couple of hours a day 3 or so days a week, just to keep all the moving parts working.
    And you're right-- by then, the only maintenance is netting debris and making sure the chlorine stays where it needs to be. It is very easy to get complacent about testing, because once the water temp gets below 60 or so, it takes a LOT longer for your chlorine to be used up, especially if your CYA is high, but believe me when I say that's a temptation that you must resist, otherwise cleaning it up is a huge chore! But it's really, really easy--I dose my pool about once every 10 days or so during the winter, and it stays crystal clear the whole time, as long as I don't get lazy about testing.......
    mroll is offline Subscriber Thread Analyst mroll 0
    Jun 2012
    Long Island, NY
    BTW How much polyquat for a 15' round AG pool?? THANKS
    15' round 5.7K gal AG vinyl pool; Bleach; Haywood DE filter; Haywood 1 1/4 pump; 4-12 hrs; Taylor K-2006 Tester; utility water; summer: solar; winter: Not bought yet; ; PF:21??
  1. closing AG pool using BBB method
    By nudedeer2 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-21-2012, 03:11 PM
  2. Winter closing IG BBB Safety Cover - Best Chemical Balance prior to closing?
    By blue wolverine in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-16-2012, 03:36 PM
  3. Why BBB Method?
    By brittmer in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-27-2007, 09:08 PM
  4. Plan on closing today, but read about polyquat dosage prior to closing...
    By The Raddish in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-06-2006, 09:50 PM
  5. The B method.....
    By matt4x4 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-30-2006, 11:34 AM
