With summer rapidly passing byI'm considering whether or not to change my closing routine. Since 2004 I've used this closing kit purchased from a local pool shop;
http://www.nationaldiscountpoolsuppl...ikitforpo.html
It contains an algaecide (looking that the label I saw no metals listed), a stain/scale inhibitor, phosphate remover, and a tablet floater with "enzymes and oxidizers". I don't have any of the bottles from last year, so I can't list specific ingredients.
The first several years I covered my pool with a mesh safety cover then switched to a solid cover (much easier spring cleanup!). If it matters, I live on the mid Atlantic coast. I usually open the pool early May and close mid to late October.
So the question is, should I keep using this kit (seems to work well) or is there a better/cheaper BBB method for closing I should consider? I read the above stickies on closing but they left me a bit confused.
Thanks.![]()
Even then, a couple times the pool was green upon opening. So far with the kit I've been using and the solid cover, I've not had any issues closing earlier and opening later. As a matter of fact, one season I had to wait until June to open due to waiting to get the liner fixed. Even then the pool was clear (and warm!).
