Results 1 to 3 of 3
Thread: New Member
    Aug 2012
    Wisconsin
    Default New Member
    Hello been pool owner for about 7 years but still trying to learn more.
    Need urgent help with alge problem that has got our local pool shop stumped and made my pool unusable for the last 3 weeks.
    Have a 24' above ground pool with a waterway pump and sand filter.
    Default Re: New Member
    Hi, and welcome to the forum!
    We'll be glad to try to help with the problems, but we're gonna need some info first--start with a set of drop-based test results on your pool, (no strips!), a list of what chems you've put into the pool (ingredients, not product names like "shock"). Also, what form of chlorine do you normally use? What does your water look like, and can you describe the problem?
    membership updated. -ben
    I'll post the info you need, to get started solving your current problem . . . and avoiding future ones!
    + It's much easier to answer your questions, when we have the details about your pool in one place. We often 'waste' the first few posts back and forth collecting information. So, please complete our new Pool Chart form -- it takes about 30 seconds, but will save much more than that.
    Pool Chart Entry Form
    + Get a cheap OTO (yellow drops) / phenol test kit, or if available at YOUR Walmart (check availability), get the HTH 6-way DROPS test kit, which is compatible with the Taylor K2006. Test the pool as soon and you can, and post the results. If you get the 6-way kit, ALSO test the water you FILL the pool with, especially if it's a well, and post THOSE results as well. (The HTH is the best available kit you're likely to find locally, but it's not the K-2006. It can only provide rough measurements chlorine levels above 5 ppm, and it measures "TOTAL" hardness, rather than "CALCIUM" hardness, which is not ideal.)
    + Having a good test kit makes pool care easier for EVERYONE, but is an ESSENTIAL tool for pools with problems. A good test kit means a kit that can test chlorine from 0 - 25 ppm, pH, alkalinity, calcium hardness, and stabilizer with reasonable accuracy. Test strips (AKA 'guess-strips' ) do NOT meet this standard. Some pool store testing is accurate; most is not. The ONLY way you'll know whether your pool store is accurate or bogus, is by testing accurately your own self. On the other hand, pool store 'computer' dosing recommendations are NEVER trustworthy -- ignore them. They are designed to sell more chemicals than you need, and WILL cause many pool problems.
    + We recommend the Taylor K-2006 test kit, which meets the requirements above, for many reasons. The HTH 6-way drops kit is a great starter kit, and is compatible with the K2006 (it's made by Taylor). There are a few alternatives; for example Lamotte makes an FAS-DPD kit that's OK -- but it costs 3x as much. But, we're not aware of any test that is better, and since we are all familiar with the K-2006 (and can help you with it) we recommend it exclusively ( Test kit info page )
    One caution for the 2012 season: Amazon does not stock the kits directly. So when buying at Amazon, Amato is our current preferred seller. However, they often don't list enough stock to last the whole day, so try order mid-morning. You should expect a delivered cost under $60 for the K2006A and under $95 for the K2006C. If you can't find that, wait a day.
    + Here are links to the kits we recommend (you can check local availability on the HTH kit, using the Walmart link):
    HTH 6-Way Test Kit @ Walmart
  1. New Member: Please Help
    By freetime in forum Above-Ground Pool Construction & Repair
    Last Post: 06-02-2013, 06:18 PM
  2. New member
    By 7sanders in forum Pool Chemistry for Intex-type Pools
    Last Post: 08-10-2012, 01:27 PM
  3. New Member-CYA
    By 392papa in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-14-2012, 10:43 PM
  4. New Member
    By amyjtaylor in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-22-2012, 03:02 PM
