Results 1 to 10 of 19
Thread: White Water Fungus among us!!
    Jul 2012
    Ohio
    Default Re: White Water Fungus among us!!
    Do I leave my ladder in the pool after I scrub it so that it can bathe in the 9 gallons of bleach and high chlorine? What about my solar cover,pool toys,floats? Thanks
    I would leave all the toys, floats, etc. in the pool, so that any remaining stuff on them is also killed. They may lighten in color a little, but I'd rather have them lighter than contaminated!
    Jul 2012
    Ohio
    Notice while sweeping that my cartridge filter must have a tear in it and is letting some debris thru. Do I put in my new filter that I have as a backup in before the fungus is gone or after?is it better to expose the we filter to it but catch the now debris possible or to stay with the defective one and let some debris pass thru?
    When it rains,it pours!!
    28' round 18K gal AG pool; Pool frog chlorinator and mineral pac; Pleatco PWWCT150 cartridge filter; Waterway 1 1/2 HP, two speeds pump; 24/7 May - Sept hrs; HTH 6way.; 4' x 20' Fafco Solar panel ; utility water; PF:6.7
    Definitely, filter.
    If you add chlorine via the skimmer (no mineral cartridge or tabs in place!!), it will keep the cartridge clean.
    Jul 2012
    Ohio
    Ok, it looks like the fungus is gone.
    I still have the Pool frog chlorine back pack wide open to 10, but I did turn the pump down to the slower setting. Thanks for the help. I received my Taylor k-2006c testing kit this afternoon and just finished my test, but will post those in a new thread.
    Thanks for the help!!!
    Jul 2012
    Ohio
    I am unable to post a new thread so I will post my K-2006c tests here. As stated previously, I am using a Pool Frog Chlorinator and mineral pack that surrounds the chlorine backpac. I am very new to doing my own pool chemistry and a bit nervous. Thanks for the help!
    PH: 6.8
    FC: 4.6
    CC: 1.0
    CYA:50
    TA: 50
    Quote Originally Posted by Ohio Canoe View Post
    You can't post in "Getting Started" any more, but you should be able to post here, without a problem. Try in the testing section, and see.
    And, add some more borax, till your pH is up some.
    Jul 2012
    Ohio
    Will do. Thanks PoolDoc.
  1. White cloudy water
    By bb158 in forum Dealing with Algae & Slime
    Last Post: 06-07-2013, 09:16 AM
  2. White Cloudy water
    By billbeard78 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-07-2012, 09:49 PM
  3. White cloudy water
    By PoolParadise in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-21-2011, 12:09 PM
  4. White flakes in water
    By steveinaz in forum Dealing with Alkalinity and Calcium
    Last Post: 06-30-2010, 08:44 AM
