Welcome to the forum and you are so very lucky to have found this forum so early in your pool experience. Let's get down to business.....
First, follow that link in PoolDocs signature that says "Get the testkits you need". I recommend since you are new at this you get the big Taylor 2006C kit which has lots and lots of extra chemicals so you can make lots of tests. You will need to do that, or shall I say, you will be wanting to do this the first couple of weeks you have the test kit so you can get everything settled down. It was the best investment I ever made for my pool. With it, the smart folks here can help you with precise instructions. That will be the key for you in the beginning......for instance, look again at the above post by PoolDoc. He gave you exactly how much one gallon of bleach with raise your chlorine level. Once you get your test kit and you see if how much more chlorine you need, you can figure that proportion to the 13ppm that one gallon will raise your chlorine level. Want to raise your level by 6ppm, that's roughly half of 13, so pour half a gallon in the pool and your done. Got it?
I want to address stabilizer......search here in the forum for positive recommendations for a stabilizer. There can be alot of junk put into a package sold as stabilizer. I believe if memory serves me right that following the link to "Get the pool chemicals you need" link of PoolDocs above will give you the fool proof stabilizer through Amazon. I got my test kit this way and will continue to use those links....it supports this forum AND in know it's the right product I need.
Get the Taylor kit and start measuring all your levels, post results back here and you will have all the help you need to get your pool up and running as painlessly as possible. There is alot of expertise here......and they are all ready and willing to help and teach you what you need to know. Believe me, it took me a couple of very hard weeks to get it figured out.
Bob E.
