inground 1 st year pool owner-
There is like a tissue paper type Substance(see through slime?) everywhere in my pool-
i tried to grab it with my fingers and it just disinagrates.
they are about 1 inch and smaller.
I had this in the spring. I decided it was pollen, plant stuff. Skimmer socks helped get rid of it.
My numbers were right and I had no algae, so again I decided it was airborne debris.
I believe i have water mold....
i just shocked it with 3lbs of shock-
will see if that helps!
the only reason i can see why this happened is,
faulty test kit!
I was showing high chlorine levels 3.0+ so i lowered then shut off the chlorine supply.. this went on for two weeks and i still showed a 3.0+ chlorine level.
time for a new test kit!
