Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 57
Thread: Fighting Algae with Borax
    Tredge is offline Registered+ Thread Analyst Tredge 0
    Wisconsin
    Default Fighting Algae with Borax
    Going to try and follow the posts in china-shop to get my borates to 50ppm.
    Bleachcalc says I will need to add 650oz or 40lbs! (40,000 gallon pool)
    Should that be right if I've never added any borax before?
    Pretty sure I shouldn't attempt to add that much at once
    Any advice on how to go about this?
    Thanks in advance
    Some people have hobbies.....I have a pool.
    waterbear's Avatar
    St. Augustine, Fl
    Default Re: Fighting Algae with Borax
    BleachCalc has an error in the borax section and it underdoses by a large margin. To get to 50 ppm in a 40k pool you will need 150 lbs of borax (sodium tetraborate decahydrate), just slightly over 31 and a half boxes of 20 mule team, and 9 gallons, 1 quart, and 1 pint of muriatic acid to neutalize the pH rise and create the borate/boric acid buffer.
    If you use sodium tetraborate pentahydrate (Proteam Supreme, Bioguard Optimizer, Omni Maximizer, Poolife Endure) then you will need 107 lbs and 8 gallons, 1 quart, and 3 ounces of muriatic acid.
    Add half the amount of borax, then half the acid, then the rest of the borax and all but 1 gallon of the remaining acid. circulate for about 24 hours and then adjust your pH to 7.6 by adding acid. If you overshoot and the pH goes too low then either add a bit more borax to bring it up or aerate the water.
    Edit: made a mistake in the amount needed for 50 ppm with the pentahydrate. 107 lbs will only gety you to 40 ppm. to get to 50 ppm you need 134 lbs and 10 gallons, and 3/4 cup acid!
    31 boxes of Borax and 9 gallons of Muriatic Acid?
    Is your problem algae or algae prevention?
    If it's algae, just attack it by the usual means. If it's algae prevention, well, enjoy yourself.
    For me, regular pool maintenance and weekly dosing with 1-2 oz of PolyQuat does it.
    Jul 2006
    Smile Re: Fighting Algae with Borax
    It really takes a lot of borax to get to 50 ppm. It may be even higher. In the past I divided the dose into quarters and adjusted the ph with acid after each dose. The thought was to prevent (or decrease) the wild pH swing the borax causes.
    I am believe that the water is sharper and more crisp looking with the borates included. This is totally subjective and cannot be proven.
    Feel safe doing it...
    25,000 IG vinyl Utopia pool
    Wisconsin
    I can assume I have 0ppm borates in the water now correct?
    Never added any before.....
    waterbear's Avatar
    St. Augustine, Fl
    If you have never used borax to adjust pH it's a safe assumption. I would pick up some AquaChek (or Proteam) borate test strips. I order my Aquachek borate strips from here:
    http://www.diywatertesting.com/
    Very fast shipping and good price!
    Wisconsin
    Just wanted to provide an Update.
    I ordered those strips and waterbear was right on target for the amount of borax to add.
    I am very pleased to report that borax works! I've had to deal with mustard algae every year (I live next to a large marsh full of it). Every year I go through a shock cycle and it never really goes away completely...until this year!
    My pool is algae free and crystal clear.....but most importantly...its staying that way without weekly shocking.
    Thanks waterbear for the help!
    waterbear's Avatar
    St. Augustine, Fl
    It wasn't me, it was the borax!
    topless is offline Registered+ Thread Analyst topless 0
    Jul 2006
    Wichita, KS
    I saw this thread and am interested in resolving my multi-year battle with mustard algae. I looked for the thread mentioned in the China Shop, but didn't see it.
    I have been shocking my pool for a month in between rains and if I don't keep the chlorine about 25ppm, the algae comes back in a day or 2. Last week I had the pool covered for 4 days while it rained and it set me back from seeing the bottom of the pool, to not being able to see the bottom step.
    The pool has been clearing back up, and can see the bottom of the shallow end, again.
    I've been lowering my TA by adding acid and aerating, which is working.
    When I opened it after the 4 days, I could see the mustard algae on the steps before I vacuumed.
    California
    The thread is here.
  1. Fighting algae, too.
    By keljoh in forum Dealing with Algae & Slime
    Last Post: 08-16-2012, 05:31 PM
  2. Fighting mustard algae, too
    By southside in forum Pool Chemistry for Intex-type Pools
    Last Post: 08-12-2012, 08:01 PM
  3. fighting algae
    By greenpoolfighter in forum Dealing with Algae & Slime
    Last Post: 07-28-2011, 03:42 PM
  4. newbie fighting algae
    By centexpool in forum Dealing with Algae & Slime
    Last Post: 08-02-2006, 08:38 PM
