Results 1 to 1 of 1
Thread: Change from sand to Zeolite, water now cloudy
    Attleboro, MA.
    Default Change from sand to Zeolite, water now cloudy
    Replaced my regular sand today with Zeolite. Guess I was supposed to backwash first before setting to filter now the pool is very couldy. I added some DE to the Zeo also. Should I turn off the filter to let the dust settle and vac to waste or keep the filter running 24/7 until clear?
    Called the Zeolite manuf. He told me to use a clarifier to help the particles collect together. The pool store I bought it from told me to use a flocculent and filter on recirculate for an hour and then if still cloudy in a day or so use a clarifier. Would rather not put this stuff in the pool if I don't have to.
    Please any advice?
    My pool water is perfectly balanced right now.
    Nicole: 18' round AG with AstralPool Sand Filter and 1.5hp AstralPool Pump
  1. Cloudy water after filter change
    By JMann in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-20-2012, 10:53 PM
  2. cloudy water with a new sand filter
    By franky2011 in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-02-2011, 03:57 PM
  3. When is it necessary to change sand?
    By debdevero in forum Pool Equipment & Operations
    Last Post: 04-21-2008, 12:17 PM
  4. Does Zeolite help in removing iron from the water?
    By smallpooldad in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-26-2006, 05:23 PM
  5. Change my sand??
    By faithfulfrank in forum Pool Equipment & Operations
    Last Post: 05-17-2006, 05:15 PM
