Day 2 of the new pool...
Things are going well, water was crystal clear when I came home from work yesterday. Finally knocked PH down to about 7.8, new plaster had it sky-high; added another pint of Muriatic acid and will check again tonight--should be right in there.
The in-floor cleaning jets work pretty well, I really like the way they keep the water circulating, and tend to bunch all the crud together in neat little piles that can be swept right down the main drains. I'm impressed with the system; I didn't really think it would work this well. They did a fantastic job on the waterfall, with water coming from 3 different directions and a very natural look.
Here's a pic of it almost full (Monday), took 30hrs and 3 hoses:
- You may not post replies
- You may not edit your posts
Forum Rules
