Results 1 to 10 of 10
Thread: Do borate products (Supreme, Optimzier, etc.)work as claimed?
    waterbear's Avatar
    St. Augustine, Fl
    Default Do borate products (Supreme, Optimzier, etc.)work as claimed?
    Several companies are selling sodium tetraborate pentahydrate as a pool additive under such names as Proteam's Supreme, Bioguard's Optimizer plus, and others. Several claims have been made for these products when used in a 30-50 ppm concentration such as:
    1) more stable pH
    2) Algaestatic properties
    3) reduced chlorine usage
    4) silkier feeling water--less skin and eye irritation
    5) clearer, 'sparkling' water
    I recently added sodium tetraborate decahydrate (20 mule team borax) to my pool to a 50 ppm concentration and adjusted the pH accordingly (just like is needed with the commercial products) and after three weeks can give some preliminary answers!
    1) more stable pH--resounding yes here. I normally need to add acid every three weeks with my SWG because my pH is 8.0....my pH climbed much more slowly and is only at 7.7 after 3 weeks. I am waiting on adding acid to see how long it takes to go higher.
    2) Algaestatic properties--unable to determine. Never had algae since the SWG went online and my phosphates are between 2000-3000 ppb
    3) reduced chlorine usage--this one might be a yes...it took me by surprise. My swg usually maintains a 4 ppm fc with a setting of 10%. My FC has been running at 5.5 ppm and I just lowered my SWG down to 6% to see where it puts my FC AND my pool had heavier usage during this period because of visiting family (with little kids!)
    4) silkier feeling water--less skin and eye irritation--although subjective this one appears to be a yes. My nephew, his wife, and their three kids (3,7 and 9 years old) were visiting for a week and they all commented on how silky (their words) the water felt. The kids said it didn't hurt their eyes like most pools do (they spent whole days in the pool) and my nephew's wife commented on how her hair didn't dry flat like it usually does after swimming in a pool. She told me that she has been in pools with SWGs before and the water was not like this. She asked what I put into the water to make it feel that way.
    5) clearer, 'sparkling' water--another subjective one but I would have to say yes. I usually have to vacumn my pool every 3 weeks or a bit more often. I usually get a bit of dirt that collects near the main drain and along one side of the deep end. After 3 weeks the pool floor is still pretty clean so I am going to see how long I can go. Also, I usually have to change out my skimmer socks weekly. I am on week 2 of the same sock now....just had to pull some leaves out of the skimmer. The water does have a 'sparkle' to it. Some of my neighbors have commented on it as well.
    The pool does seem to be clearer and 'bluer' looking but, like I said, this is subjective. At night when the lights are on the water also seems to have more 'sparkle' and clarity.
    I will continue to monitor and post my test results in this thread
    http://www.poolforum.com/pf2/showthread.php?t=4712
    for anyone interested in the details.
    What have I concluded so far as to whether tetraborate products live up to the claims made for them?
    A definite YES for claims 1, 4, and 5!
    A possible YES for claim 3. I will be monitoring this one closely!
    Can't really tell for claim 4 but this is why borates were used as a pool additive in the first place so I think this one might have some merit based on some research I have done on the internet about borates as a herbacide and algaecide.
    BTW, the cost of adding the borates to my 6600 gal pool (and 300 gal spa) was about $35 and that was for 6 boxes of borax (didn't need all 6), 2 gallons of acid, and a jar of borate test strips.
    sailork is offline Registered+ Thread Analyst sailork 0
    Houston (Clear Lake area), TX
    Default Re: Do borate products (Supreme, Optimzier, etc.)work as claimed?
    I suspect one of the reasons you're seeing less chlorine consumption is that the boron is keeping some of the organics in check. Most marine diesels around here add boron based products to the fuel to keep fungus from growing. If it will kill fungus that lives in diesel fuel it's bound to kill some of the buggers in a pool.
    I'm very tempted to add borax to my pool, but I'm put off by the idea of using a bunch of HCl to bring my already high pH back down. What would be wrong with adding boric acid? Would I get a different result?
    22,000 gal gunite pool, 1.5 hp pump, DE filter, and dreams of a SWG.
    waterbear's Avatar
    St. Augustine, Fl
    I do know that some of the montly and weekly treatments that are used with borates contain both tetraborates and boric acid or sodium bisulfate (dry acid) so the pH rise does not occur. Proteam's Weekly Treat is an example that contains tetraborates and dry acid but it is supposed to be used in a pool that already has the borates added just to help maintain levels lost by backwashing. Also, Salt Water Magic montly by Natural Chemisty also contains both tetraborate and boric acid for the same reason. I suspect the problem is that boric acid is not that soluable in the amount neededand by itself would probably have negative impact on the ph as well that is not as easy to adjust.
    I just added the tetraborate (borax) and the acid since this is what you would do if you were adding Supreme or Optimizer (or one of the other commercial products) to the pool initially.
    Adding the acid is pretty easy, for each 4lb 12 oz box of borax first put 5 cups of acid into the water and then add the borax....then add 5 cups more acid and another box of borax until you reach the target level. For more precise dosing read these two posts
    http://www.poolforum.com/pf2/showpos...8&postcount=21
    http://www.poolforum.com/pf2/showpos...7&postcount=22
    Just remember to add enough acid first to neutralize the pH of approx 10 lbs of borax added at a time and then alternate adding the acid and borax until you reach your target.
    California
    I posted some info on the other tetraborate thread, but I did find this WHO document full of some useful information. It would appear that, at least in simulated seawater, 100 ppm is more effective in inhibiting or killing algae than 50 ppm, but pool water is not sea water. There seems to be no question that Boric Acid (or its borate ion) inhibit growth of several kinds of microorganisms, but I just find it suprising to see the relatively large drop in chlorine usage that Evan (waterbear) has noticed so far. Most chlorine loss is during the day due to breakdown from sunlight (UV) so to truly cut down chlorine consumption significantly a substance has to prevent this loss. My concern would be that the mechanism for this (if it exists) could be similar to CYA and that could mean a reduction in chlorine effectiveness.
    Also, with regard to adding a bunch of HCl to the pool, remember that the combination of adding Borax and Muriatic Acid gives you the boric acid you want plus salt (NaCl). That is, the end result is nothing nearly as toxic as the original HCl you started with. It's kind of like adding Muriatic Acid (HCl) with Lye (NaOH) to produce salt and water. You can't think of the result of mixing toxic chemicals as producing a toxic result. I agree that Muriatic Acid is a bit of a pain to handle, but using gloves and holding one's breath or looking away should be sufficient precaution (wearing glasses would be an extra safety factor in case of splashing of drops).
    Richard
    ChemGeek, If you've read my other posts you know that I actually like muriatic acid and get into the pool when I add it. (Goggles on.) My pool drinks the stuff by the gallon. I'm only interested in adding boric acid because as far as I can tell I get exactly the same result without having to use (pay for, measure, etc.) muriatic acid. Call me a purist?
    Talking Re: Do borate products (Supreme, Optimzier, etc.)work as claimed?
    WB, welcome to the forum! As you are new to both pool ownership and the forum, I suggest you read all the 'stickies' at the top of each topic and give poolsolutions a good read. Caring for a pool doesn't have to be hard, if you follow the guidlines here you can all but eliminate the problems that so many pool owners experience. In the future , it might help to post in the correct area, (I see that this one is in the 'bathing suits and loungechair section') as that will allow more people who could answer your question to see it.
    With reguard to your question, I'll have to pass this on to Evan, he's currently conducting an experiment on his own poolwhich almost mirrors your querry. With any luck, he'll know what's going on (he really knows his shi*). BTW, I don't really know anything about pools, but I stayed at a Holiday Inn Express.
    Seriously, thanks to your 'experiment' and comments (findings), I think I'll start refering to Proteam by their rightful name - again, thanks Evan for all you do here and all the great help you provide!! - Ted
    waterbear's Avatar
    St. Augustine, Fl
    Ted,
    What can I say...I've always liked chemistry sets and now have a 6600 gallon one in my backyard!
    Seriously though, it was your rant on Proteam in the china shop a while back that got me thinking about trying this since we sell the Proteam line where I work. The products in their line that I have used I have been very pleased with (Metal Magic is a prime example) but I had my own doubts about the claims for Supreme (and I distrust ANYTHING Bioguard says!) I really didn't expect the results to be so successful and time will tell if it works over the long haul. Unfortunately, I can't recommend borax at work but I have turned many of my customers on to this forum. The other ones (that just want a magic bottle for their pool problems) I can now recommend Supreme to because I know it will help.
    I've looked at Evan and Richard's discussion regarding the dosage of borax and HCl per 1000 gallons. If they've got their numbers right it would mean a 22,000 gallon pool would require 17 boxes of borax and 5 gallons of muriatic acid. That sounds about right compared to the ProTeam Supreme dosage instructions. But that's more than $100 worth of chemicals. Cheaper than Proteam Supreme but I think I'll hold off for a bit and see if the Waterbear is still seeing good results after a week.
    So, Evan, I've been waiting with bated breath. Does your pool still hold chlorine better than it did before you added Borax? Is the pool still sparklier and less eye-stingy? Can we call this technique "ProBear Supreme?"
  1. Once hardened, will borate dissolve?
    By JimK in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-27-2012, 11:28 PM
  2. Borate application, redux
    By waterbear in forum The China Shop
    Last Post: 02-10-2012, 03:04 PM
  3. Borate test strips
    By waterbear in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-02-2007, 09:37 PM
  4. High Borate (Borax)
    By rhludwig in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-10-2006, 11:48 PM
  5. ProTeam Supreme
    By teja1946 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-12-2006, 09:34 AM
