I have the PS234S - upgraded form the 233. I just did the salt test last night and it says I have 4000ppm Salt. I did it a second time (same water sample) and got 4200ppm.
I don't think this is correct. First my IntelliChlor SWG says my salt level is 2700 ppm (add salt light is on), and second I can't taste the salt like I did before when I had 3500ppm (confirmed by pool store).
I'm going to get a test from one of the pool stores today to see what they say and to pick up some more salt.
Is there anything I could have done wrong to throw off the PS234S test?
I added the 2ml pool water followed by the one drop Salt regaent #1, followed by the distilled water to the line on test tube. Then I added drops of regaent #2 (swirling inbetween) until the liquid stayed an orange color. It took twenty drops.
The pool pump was not running for about 2 or 3 hours prior to the test. The water temp was around 88 degrees.
