I am not a vinyl pool expert - but I am in the process of builsing a pool. Other things you need to consider are:
- References - those who have used the same company and you should try to get references provided by the building department (from permits) - not from the pool builder
- Any company you are considering - that they install vinyl pools all the time (not just a few a year)
- If you have neighbors that you will need to use their land for access - get a use agreement signed and also get pictures pre-pool installation of EVERYTHING
As far as the size of the pump - with a sand filter you can get a pump that is TOO large and it will actually force dirt through the sand (bad). I'm sure an equipment expert can help you determine how long it would take to turn the water over once. You want to turn the water over twice in a day. Also - I didn't see anything about solar or water features - those would impact the pump size as well.
Good luck!![]()
