Results 1 to 10 of 29
Thread: For those of you using Bleach...
Threaded View
    leejp is offline Registered+ Thread Analyst leejp 0
    Upstate, NY (Dutchess County)
    Default Bleach Usage Survey...
    How much (in PPM) does your pool consume each day? And at what CYA?
    I know it varies by weather, amount of sun exposure, use of the pool, stuff falling into the pool... but if enough folks respond, maybe we can get a starting point rule of thumb for those like me converting to the BBB method.
    This is my first year on Bleach (actually, I used tri-chlor until my CYA got to 40 then switched to Bleach). I've also had to go through an iron stain removal procedure (unfortunately 2x) and have yet to "zero in" on my pool's bleach consumption.
    Here's my highly unscientific data collection as of today. Latest #'s. I took vanhout's suggestion and changes the title of the post (hope it'll take). keep those #'s coming...
    Last edited by leejp; 07-19-2006 at 02:23 PM. Reason: Update with additional member input
    26,000 Vynil Liner L Inground
    Hayward 1HP Superpump + Hayward Pro Grid 4800 DE Filter
    Poolvergnuegen thepoolcleaner Pressure Side Cleaner
    Loop-Loc Mesh cover
