Results 1 to 10 of 29
Thread: For those of you using Bleach...
    Berwyn, PA
    Default Re: For those of you using Bleach...
    I'm just like you - CYA at 40, started using bleach this year. (I've been using pucks for 12 years, though, so for me, clearly something always eats CYA over the winter.) I seem to need a 3-quart jug of bleach every two days, so by my calculations I'm losing about .7 ppm per day.
    Pool is in full sun for about 5-6 hours a day. Bather load is very light, but leaves, etc. are probably worse than most people's.
    23' x 41' 32k gal plaster circa 1991, 600 gal spa with overflow
    Ultraflow pumps, Titan SS filter, Sta-Rite heater, Polaris 180
    Homegrown X-10 automation -- filter, cleaner, valves, lights, chlorination
    joliecharlie is offline ** No working email address ** Thread Analyst joliecharlie 0
    Pinehurst, North Carolina
    50 CYA, holds chlorine overnight but loses 5-7ppm on hot sunny days. Full sun 9am-6pm, no shade, little debris, light swimmer load. I am running pucks again in autochlorinator set on 1/2, test chlorine nightly and add accordingly.
    18x26 inground vinyl
    Howell, Michigan
    Excellent thread,
    <30 CYA, 2 - 3 ppm / day
    graciec is offline Registered+ Thread Analyst graciec 0
    Thumbs up Re: For those of you using Bleach...
    Dr Spike...this is off topic...So excited to see you have a dome!!!!! how do you like your dome?
    We are in Michigan and I want one!!!!!! If they move this question off this board, can I ask you on the off topic board??
    Tennessee
    Full sun 8 hours day. Loose about 2 to 3 ppm each day. Add 1 qt one day 2 qt the next. CYA 35 to 40 ppm.
    jmjbj_h Guest
    My CYA is 45 and I am losing about 2-3ppm a day. Full sun and medium/heavy bather load. Mostly several kids under 6. Can anyone say...toilet? I put in a bottle a day
    Joe
    Sun Prairie, WI
    Quote Originally Posted by graciec
    Graciec,
    I do like the dome, we should move the dome discussion to the off topic forum and not hijack this thread.
    ~Dr. Spike
    Pool: IG vinyl, heated, fully enclosed (dome)
    Shape: Grecian (rectangular)
    Size: 20'W x 40'L
    Depth: 4' / 8'
    Filter: Sand w/DE added
    Other: 6' Diving Board
    Maintenance: BBB! Ben's PS234 kit! Manual vacuum, brush, and Pool Buster Max CG Gold
    The answer to your question is a function of both CYA and FC (total free chlorine) levels since twice the chlorine level loses about twice the amount of chlorine per day. I now have around 15 CYA and 2-3 ppm FC and lose about 0.5 ppm per day. The pool is normally covered and is open to sunlight (it's an outdoor pool) about 14 hours per week. I used to have more CYA, but had more chlorine and the rate of loss was about the same.
    Barstow, CA.
    Holds overnight, uses ~2ppm during our very hot & very sunny days. CYA ~50, water temps 90-94.
    12,000 gallon Hawaiian Fiberglass
    CFR 100 Jacuzzi Cartridge
    Berwyn, PA
    Quote Originally Posted by chem geek
    If this is the case, then perhaps we should all be reporting the percentage drop in PPM that we experience each day, rather than the PPM itself?
    I wouldn't have thought it was quite that linear - certainly chlorine loss after shocking seems much faster (even in percentage terms) than regular chlorine loss.
