Results 1 to 10 of 40
Thread: Could this be algae or dirt/pollen?
Threaded View
    South Central PA
    Default Could this be algae or dirt/pollen?
    I'm getting mixed feelings about this. We have had this show up in the pool. I shocked (with granular chlorine) and the chlorine level maintained somewhere between 5-10 the following day (using test strip). The pool company said I needed to brush the stuff off the floor to "meet" the chlorine, which I did. Still got the same chlorine reading the following morning.
    The pictures posted are after we returned from a short vacation. The entire pool floor was covered. Assuming it was algae, I turned off the filter and triple shocked and brushed the entire pool floor. The following morning, I tested the chlorine and it was at least 10ppm (test strip doesn't go any higher). Now I'm back to thinking it's only dirt/pollen, so I started the filter and poured in clarifier. That was 2 days ago. The water is now dirty and cloudy and I can't see the deep end drain.
    Specifics, if you need them (chemicals based on closest color test strip):
    30,000 gal in ground vinyl liner
    PH - 7.8
    Alkalinity - 120
    Total & Free Chlorine - 10 or above
    Cyanuric Acid/Conditioner - between 50 and 100
    Thanks so much for your help,
    David
  1. mustard algae, pollen, or ecoklean
    By shane in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-25-2012, 11:53 PM
  2. MarineCorpsMom had apparent algae or pollen/dirt
    By MarineCorpsMom in forum Dealing with Algae & Slime
    Last Post: 05-30-2011, 06:24 PM
  3. Algae or pollen??
    By DennyB65 in forum Dealing with Algae & Slime
    Last Post: 05-16-2011, 09:10 PM
  4. Algae or Pollen/Dirt
    By TJNav in forum Dealing with Algae & Slime
    Last Post: 06-06-2010, 07:56 AM
  5. Pollen or Mustard Algae?
    By 4KidsSwim in forum Dealing with Algae & Slime
    Last Post: 06-17-2008, 11:56 AM
