Results 1 to 5 of 5
Thread: Brass coupling on fire hose <=> 1 1/2" PVC ?
    Default Brass coupling on fire hose <=> 1 1/2" PVC ?
    I have a nice fire hose that I want to use for backwashing. It has a brass coupling on it that says 1 1/2", but it does not mate with any 1 1/2 " PVC couplings that I have. Is anyone aware of a way to make this work?
    Default Re: Brass coupling on fire hose <=> 1 1/2" PVC ?
    From the McMaster-Carr website I found the following information:
    There are two main types of fire hose thread. NH (National Hose) , also known as NST (National Standard Thread) is the most common; it is not compatible with any other thread. NPSH (National Pipe Straight Hose) is also a popular choice; female NPSH threads are compatible with male NPT and NPSM (National Pipe Straight Mechanical) threads
    They do sell an adapter that will go from NH/NST to NPT go to http://www.mcmaster.com/ and look for item number 6523T11. They also have various other sizes and combinations.
    I have no affiliation with the above mentioned company other then a very satisfied customer. They typically only charge actual shipping costs with no handling fees. If it is in stock (it will tell you if it is) it ships within hours of placing your order. They seem to be unbelievably efficient.
    KurtV is offline Registered+ Widget Weaver KurtV 0
    Mandeville, LA, USA.
    Greenlight, That's a great idea. I nosed around the web a bit after reading your post and Todd's excellent information and found some fire hoses and adaptors on Ebay (what isn't available there?). You might want to check that out, as well.
    Would love to hear how yours works out once you've got it going.
    kv
    I searched on eBay and asked a seller which item I needed. He pointed to this one:
    http://cgi.ebay.com/NEW-Fire-Hose-Br...QQcmdZViewItem
    or search for item 7769289291
    It has a male NST end to fit my fire hose, and a female NPT end that the seller says will fit the PVC threads. I am going to buy one, I will let you know how it works.
    Quote Originally Posted by ToddLV
    Thanks for all of this great information - I found a similar item on eBay for less money and will see how it works.
    I got this fire hose at a garage sale for $10, which is similar to what McMaster-Carr sells for over $100.
  1. How do you attach universal vacuum hose to 16" sand filter pump?
    By cporte15 in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-07-2013, 10:08 AM
  2. Convert intex pool from 1.5 to 2" hose
    By anIceFan in forum Intex-type Pool Setup & Operations
    Last Post: 05-28-2012, 08:46 PM
  3. Opinions on a fix for a DE3600 Brass Sleeve Nut
    By Manslick in forum Pool Equipment & Operations
    Last Post: 06-04-2011, 01:10 PM
  4. How does pool cover attach to brass embeds in deck?
    By aquarium in forum Pool Equipment & Operations
    Last Post: 07-31-2006, 06:47 PM
  5. Coupling s-steel pipe to flex PVC
    By Dan264 in forum Pool Equipment & Operations
    Last Post: 06-11-2006, 11:03 PM
