Thread: The BBB Method...B-B-B...What is THAT????
Threaded View
    Exclamation The BBB Method...B-B-B...What is THAT????
    They stand for the supermarket chemicals:
    Bleach for chlorine--regular or ultra unscented. 1 gallon of regular bleach, with a 5.25% concentration will add 5.25ppm of Free Chlorine (the good stuff--FC) to 10,000 gallons of water. 1 gallon of Ultra at 6% will add 6ppm of FC to 10,000 gallons of water.
    Borax for raising pH--"20 Mule Team Borax" at the supermarket, and
    Baking Soda for raising Total Alkalinity. Good Ol' Arm & Hammer--or generic.
    We also generally use Muriatic Acid to lower pH--this is available at hardware and tile stores. But Dry Acid is OK to use as well.
    From the Pool Store, you need only CYA/Stabilizer/Cyanuric Acid (all the same thing) and if you MUST have an algaecide, use Polyquat 60%... it's not a brand, you look at the label and if it says "Poly [oxyethylene (dimethyliminio) ethylene (dimethyliminio) ethylene dichloride]" and nothing else, or "inert ingredients" that's the stuff. It can be called Algaecide, Black Algaecide, Mustard Out, etc....check the label and go by that.
  1. BBB method?
    By sahari in forum --cleanup--
    Last Post: 06-10-2013, 12:02 AM
  2. What's the BBB method?
    By PoolDoc in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 03-25-2011, 10:16 PM
  3. New to BBB Method ... 100 CYA
    By tabjraxa in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-05-2009, 11:47 PM
  4. BBB Method - what is it??
    By lovedisney in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-01-2007, 11:21 AM
  5. The B method.....
    By matt4x4 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-30-2006, 12:34 PM
