PS234 First Test results... Am I doing this correctly?
FC=39PPM (Yikes!!!)- added a level scoop of DPD powder, not a rounded scoop correct?
- DPD #2 solution dropper bottle is VERY difficult to control! I get much smaller drops in rapid succession. The small drops come so fast that it's very hard to count the drops. I ran the test twice and tried to vary how I was squeezing the bottle, no luck. Is this supposed to be this difficult? I can't imagine EVER getting accurate results with this.
CC=1.5PPM - I do smell a bit of chlorine so this is probably correct.
- The DPD #2 solution dropper bottle is easy to control (as with other dropper bottles in the kit) and drops look consistent in size with the other drop test kits I've had
PH = 7.5
ALK=120
- color goes from green to purple to red, normal?
CAL = 50
- color change is almost instantaneous
CYA ~ 20
- I can barely see the dot with all the solution in the tube. This is about what I expected since I opened to 0 CYA this year (according to guess strips). I've added but it's been quite cold here in the Northease and I suspect it'll be a while to dissolve.
Alll in all pretty straightforward but I'm really worried about the FC reading. I actually hope there's something wrong with my dropper bottle (what do I do if this is the case?)... again, the drops are MUCH smaller than from any other bottle in the kit.
26,000 Vynil Liner L Inground
Hayward 1HP Superpump + Hayward Pro Grid 4800 DE Filter
Poolvergnuegen thepoolcleaner Pressure Side Cleaner
Loop-Loc Mesh cover
