Results 1 to 5 of 5
Thread: Adding CYA (Stabilizer) My Way - Lesson Learned
    PatL34 is offline Lifetime Member Widget Weaver PatL34 2 stars PatL34 2 stars
    Saint Cloud, FL
    Default Adding CYA (Stabilizer) My Way - Lesson Learned
    After trying various ways to add CYA to the pool that is most effective in dissolving it in record time, I came up with the following "patented" method.
    Using a pool rake with a fine mesh basket, place it so that the basket is over one of the returns which has been adjusted slightly upwards to direct the flow onto the mesh part. I use a concrete cinder block as a counterweight.
    The method has the following advantages:
    1. I can dissolve 2 lbs of CYA in about 24 hours.
    2. I can still keep on vacuuming and maintain flow to the SWG, which would have been questionable, if the CYA had been poured through the skimmer. I have a DE filter.
    3. The return jet creates a substantial disturbance in the mesh basket, to help the CYA dissolve faster.
    Hope this helps.
    Pat
    tundraSQ is offline Registered+ Thread Analyst tundraSQ 0
    Default Re: Adding CYA (Stabilizer) My Way - Lesson Learned
    Did not work for me due to the mesh in my leaf rake..but i did end up with a 1/2 pound of CYA sitting on the bottom of my pool whihc I vacuumed into the filter...whihc I think is where it is supposed to go anyway...I just got it there in a different way*LOL*
    Saint Cloud, FL
    There's the rub. You have to use a fine mesh basket for this to work, otherwise as you say, it goes to the pool bottom.
    Pat
    Quote Originally Posted by PatL34
    Pat
    yes I do agree that the idea is brilliant...had I been smart I would hve dumped the CYA into a nylon and THEN tossed the nylon into the pool rake.
    Dec 2005
    Honolulu, Hawaii.
    Great idea, thank you.
    I have to do my stepson's pool this week as he is having a second birthday party for our grandson. This at least will speed up the process.
    He has not maintained his pool properly in 5 years and now wants me to get it ready so our grandson can learn to swim. Good idea as I nearly drowned when I was seven.
    One learns so much on this site that is why I love it.
  1. Adding stabilizer
    By dedkrd in forum Dealing with Algae & Slime
    Last Post: 07-21-2011, 04:48 PM
  2. Ok, my lesson learned the hard way.......
    By aylad in forum In-Ground Pool Construction and Repair
    Last Post: 05-21-2010, 02:57 PM
  3. Learned My Lesson
    By karrde97 in forum Dealing with Algae & Slime
    Last Post: 06-06-2007, 08:07 PM
  4. Adding Stabilizer to adjust CYA
    By waltham41 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-08-2006, 01:52 PM
  5. DE Filters - Lesson Learned
    By rhosk in forum Pool Equipment & Operations
    Last Post: 05-10-2006, 03:59 PM
