Closed Thread
Results 1 to 3 of 3
Thread: Green pool "blues"
    Jun 2010
    Just south of Atlanta, GA
    Default Green pool "blues"
    After dropping too much money at a local pool store I happened on your forum. Looks good! A few particulars:
    25,000 in ground
    vinyl liner
    SWG
    Lots of sun. We're just south of Hotlanta, Georgia
    Pool store tests:
    Saturation index-0.8
    TDS 4500
    CYA 90
    Total Cl 1
    Free Cl 0
    pH 7.8
    Tot alk 50
    Tot hardness 75
    sturev's Avatar
    sturev is offline Registered+ Thread Analyst sturev 0
    May 2010
    Default Re: Green pool "blues"
    What does your water look like? You need to get some chlorine in there ASAP.
    Evan S.
    AG FastLane Pool, 9x13 ~ 3,000 gal, COVERED/INSULATED 23X7, 30 gpm water pump (runs 12 hrs a day) AND a Hayward Power-Flo LX 1.5 hp Pump (only used on occasion for the pool sweep), Hayward 100K BTU Heater, Waterway Flo-Pro Skim Filter & Slime Bag, no other filters
    I'm locking this thread so that all the advice given to this poster can be in the same place. To assist him, please see his other thread.
    Edit: To George in Georgia, It makes it much easier on those offering assistance if all of the information about a particular problem is kept within the same thread, rather than being spread around in different places on the forum. It also helps us keep the forum somewhat organized. Thanks!
Closed Thread
  1. I have the "pinks" (instead of the blues!).
    By onemsmom in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-27-2012, 03:55 PM
  2. Can a leaking Jandy "Check Valve" with clear top be "fixed"?
    By 105ex in forum Pool Equipment & Operations
    Last Post: 05-29-2010, 09:17 AM
  3. Changing AG pool depth from 52"-54" to 46"-48" for kids (shallow end tricks)
    By zephans in forum Above-Ground Pool Construction & Repair
    Last Post: 06-02-2007, 12:28 PM
  4. "Green, Cloudy, Disgusting Pool?" Why yes, thanks for asking....
    By CelticDaddio in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-22-2007, 08:27 PM
  5. Esther Williams "Millenium" Pool Install "issue"
    By mrpurrhead in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 11:34 PM
