Results 1 to 10 of 12
Thread: Green Water
    Cleveland, OH
    Default Green Water
    While I was away this weekend my water turned green. I was only away for a couple days but my water is completley green.
    So anyway where do I start? What chemicals can I use to kill the alge and get the water clear again.
    I have a 24' AG pool and dumped 2 gallons of bleach in to start.
    Thanks,
    Frank
    Cleveland, OH
    Default Re: Green Water
    Any paticular number that are more important than others? Obviously the Chorline level will be very high?
    Should I leave my filter on overnight?
    Cleveland, OH
    CL is too high to register
    PH is about 7.8 or a touch lower
    CYA is 30
    Run your chlorine up to 15 ppm, hold it there by testing and adding bleach 2-3 times daily, keep your pump running while doing this, backwashing as necessary. You also need to be brushing daily. Keep this up until the water goes to cloudy blue, then let your Cl level drift back down and keep your filter running to clear out the dead algae.
  1. light green water due to metal in my well water
    By marios in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-17-2013, 08:48 PM
  2. Replies: 8
    Last Post: 08-04-2012, 11:43 PM
  3. green water or green liner?
    By denanbob in forum Dealing with Algae & Slime
    Last Post: 05-26-2011, 12:16 PM
  4. green water that won't go away
    By kinneydd in forum Dealing with Algae & Slime
    Last Post: 06-30-2006, 09:40 PM
