Bucket test gave me approximately 14.5%. The sale ends today Btw.
25'x40' oval 33K gal IG concrete pool; hand fed liquid chlorine; Hayward S244T sand filter; Hawyard Super pump 1.5 HP pump; hrs; Taylor K-2006C; city; PF:3.6
I went to Menard's this evening to buy some of this stuff and I couldn't find it. What section is it in? I looked near laundry detergent and pool supplies. I found some "outdoor bleach cleaner" with the cleaning supplies, but I couldn't find anything on the label that said what the chlorine content was, or what other ingredients were in it, so I decided not to take a chance on it.
18x36 rectangle 20.6K* gal IG painted concrete pool; floater; Pentair Tagelus sand filter; Pentair SuperFlo 1.65HP pump; 12 hrs; gas heater; K2006 Taylor; utility water; summer: none; winter: Haven't gotten to my first winter yet; none; PF:5.8
It was near all of the pool supplies at our Menards... It's labeled "Clear Extreme Pool Shock" (white and blue label) Look for the bottle of neon yellow colored liquid.
I bought some of it and did a bucket test and mine showed 10%. I wish somebody could explain the 15% available chlorine and 12.5% sodium hypochlorite. I really think the 12.5% number is the one it's supposed to be. I'm confused by your 14.5% result since I think 12.5% should be the highest you should get. I could be wrong though....it's happened before...lol.
I believe the difference in the label of 15% available chlorine and 12.5% sodium hypochlorite may be difference in units - weight vs concentration.
The difference in test results has to do with freshness. Bleach (sodium hypochlorite solution) degrades very quickly when exposed to warm temperatures and sunlight. The manufacturer / packager bottles it at a higher concentration than the label in the hopes of still having the label concentration when it gets to the store.
The stuff I bought was still in the 4 pack cardboard carrier. There were several loose bottles floating around the display but since chlorine can degrade under sunlight I opted for those in the boxes. Mine had manufacturers date stamps of June 2012, so they were relatively fresh.
How would a gallon of 6% bleach compare to a 1lb bag of shock?
Would depend on the contents of the "shock". If it was dichlor then as far as chlorine goes its pretty close to the same dose as a gallon of 6% bleach. (Though bleach normally comes in 96oz containers) If it was cal-hypo then it would depend on the percent concentration on the packaging. However both dichlor and cal-hypo have effects on other areas of pool chemistry. Dichlor will raise your cya and cal-hypo your calcium hardness. If you need a boost in these areas then it's probably not such a bad thing to use them occasionally but not as your primary source of chlorine, even if you do find some super cheap.
