Thread: High ph
    Default Re: High ph
    Evan, apparently the puck is not only baking soda but also has a clarifier in it. (See post #4 in this thread: http://www.poolforum.com/pf2/showthr...-Clear-Balance ) Either way, as you pointed out --- she doesn't need them.
    Default Re: High ph
    Yeah, I know that. It's still over 86% baking soda and the rest is clarifier and other ingredients (read filler) so my guess is a small amount of sodium polyacylate or other clarifier and the rest are binders and the reason for the clarifier is most likely to keep the binders from clouding the water. For all practical purposes it's just a tab of baking soda and the primary effect of using it would be to cause the TA and pH to go up.
  1. Advice Needed - High CYA, High Nitrates, and Lots of Algae
    By capshockeyfan in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-03-2012, 04:47 PM
  2. High amounts of DPD Powder needed!! To high or no Clorine?
    By KaseyNewman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 01-16-2012, 10:52 PM
  3. High Phosphates > 1,000 & High Nitrates 90ppm
    By applepar in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-23-2011, 04:49 PM
  4. had algae, PH high, TA high, water now cloudy
    By Mom4fun in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-12-2011, 12:09 PM
