Results 1 to 10 of 61
Thread: Cloudy.. impatient
    Muskegon, Michigan
    Default Re: Cloudy.. impatient
    Quote Originally Posted by chuck9997 View Post
    I hope someone will notice this thread again,.. and comment I am a bit concerned... Its been SHOCK level.. and adding bleach day and night for 10 or 11 days. STILL CLOUDY.. any other suggestions?
    getting tired of spending $10 a day for bleach.
    tonight:
    todays readings:
    FC 15ppm
    CC just a trace .5
    PH 7.2
    CYA 30-40
    ALK 80
    I have done this for about 5 years.. and always get clear water by day 3 or 4.. what is the problem?
    Hi Chuck- It took me 3 weeks to get my pool clear. I've been following the teachings of this site for 6-7 years and last year was the first time I had issues with cloudy water over an extended period of time. It usually took me 3-4 days, like you, to get it clear by shocking and running the pump 24/7. I too believe the issue this year (at least for me) was the lack of winter (80 plus degrees in March), and a load of oak leaves in my pool (my neighbors monster oaks are coming down some night!). At any rate, you'll get there, just stay the course. Did I mention it took me THREE WEEKS to get my pool clear? Just hang in there.
    Michigan (Go Blue!), 18X36 IG Vinyl, 20,000 gal, 3/4 H.P. Sta-Rite Pump, Purex Triton "Tagelus" TA-60/60D Sand Filter (325 lbs.), 200M Purex Triton Minimax plus pool heater. Using old PS232 Kit and purchase Taylor refill chems.
    Tennessee.
    Quote Originally Posted by Guppy View Post
    very similar situation as myself.. thanks for responding. Do you mind telling me how it finally worked out? I am algae free and am letting the FC drift down a little. I have always been the kind of pool owner who ran the FC a little higher than needed.. probably just a mind game I play with myself. I am running the pump all the time.. have a skimmer sock in place and a little DE in the sand filter.
    I really think the pool is clearing.. but its soooooo slow. did you use anything other than filtration? Any skimmer socks, DE, clarifiers?.. etc??
    Swimming pool.. or camper? Swimming pool.. or camper? ...what the heck.. buy both.
    BigDave's Avatar
    Great News!
    Now filter filter filter.
    scootchu is offline Registered+ Thread Analyst scootchu 0
    I just went through this and I know I might get bashed, but I added... flocculant. My water had been filtering for 2 weeks and I had been adding shock levels of Chlorine, but was still blue and cloudy. The floc worked and I vacuumed to waste. I had run out of DE for my sand filter and after purchasing more I have a crystal clear pool.
    The pool mess was my own fault. I waited too long to cover in the Fall.
    Muskegon, Michigan
    Hi Chuck- I am crystal clear after 3 weeks of patiently following the this BBB protocol everyone is recommending to you. As you progress (stay the course) you will notice your pool slowly clearing until you are crystal clear. I now keep my stabilizer (Cyan) at ~40PPM, my FC at 6-8 PPM (once pool is fully clear), and then shock (20ppm) generally on Sunday night every other week or weekly, especially after heavy use. My pH hangs around 7.6-7.8 and I hit my pool with a half box of borax when my pH drops below 7.4. I like to run my pH on the higher side and have found that my pool seems to like it there as well. I don't use polyquat anymore, don't seem to need it, just bleach. Tons of great advice on this site, you"ll get there even though you think you won't. Oh yeah, I also used about 1/3 cup (based on an 8oz cup size) of DE in my sand filter, which helps clear the cloudiness, and I use the filter socks over my filter basket. That's it, good luck to you!
    Tennessee.
    I can see the bottom of the pool.. not clear.. but I can see the bottom. Well enough to see it needs sweeping. I am glad for that.. it means the water is going in the right direction. Gonna raise the water level tonight by a couple of inches.. then get in the pool tomorrow and vacuum to waste. Glad I haven't added anything other than DE, so far.
    Keeping FC around 6ppm
    CC .5 or less
    PH 7.4
    CYA 30-40
    BigDave's Avatar
    Great News! Thanks!
    Tennessee.
    Raised the water level.. and vacuumed to waste Saturday morning. We actually enjoyed the pool Saturday afternoon. The pool is still cloudy. I can see the bottom pretty good.. and it is better than it was two weeks ago. All readings are in normal range (as posted above). Still using skimmer socks.
    I will watch it for a few days and see if the water clears anymore. Seems I read somewhere that someone added POLYQUAT 60.. and it cleared the water. In fact .. I think I may have done that one year.. not sure. I thought PQ was a preventative?? Would it clear the water?
    BigDave's Avatar
    CarlD recommend polyquat to you in this thread and I asked if you'd considered it. You've probably read about it elsewhere as well.
    Polyquat is an algecide but works best to prevent rather that kill algae. Polyquat also can act as a clarifier and should help clear the water. Keep a close watch of your FC if you do decide to use polyquat. As Watermom pointed out: the polyquat will create a chlorine demand and you don't want to start another algae bloom.
  1. From cloudy green to cloudy blue
    By Dydylynn in forum Dealing with Algae & Slime
    Last Post: 06-10-2012, 05:09 PM
  2. Cloudy ,Cloudy,Cloudy... for a week now.
    By uwinsome in forum Dealing with Algae & Slime
    Last Post: 07-14-2011, 05:55 PM
  3. BROWN/GREEN POOL due to Impatient Husband
    By muleheaded in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-11-2008, 05:51 PM
