Welcome to the forum.
I don't know much about DE filters but it sounds like you didn't do anything wrong. When you added the 6# of DE did you mix it with water in a bucket first to make a slurry then pour it slowly into the skimmer? Since the skimmer and pump baskets are clean and you do have reduced flow my next guess would be a gunked up impeller. You mentioned doghair so I also assume you have to deal with a hair issue before. This stuff could easily get tangled in the impeller. Kill power to make sure the pump cannot come on accidentally, remove the pump basket and reach in the hole to the pump. If you feel hairs or stuff in there you can use a stiff hooked wire to clean it out. Since your pressure is zero that rules out a problem on the pressure side so we look to the suction side. If the suction line from the skimmer is clear, baskets are clear, no air leaks, then the only thing left is that impeller. Let's see what you find.
Hope this helps.
