Results 1 to 10 of 22
Thread: High Phosphates > 1,000 & High Nitrates 90ppm
    Yeggim is offline Registered+ Thread Analyst Yeggim 0
    Aug 2010
    Philly
    Default Re: High Phosphates > 1,000 & High Nitrates 90ppm
    Not your fault; mine, with help from vBulletin.
    You should see more, now, plus get notifications on posts you've made.
    Ben, I had to go into Settings and check mark view signatures in the Thread Display Options. I don't think I unchecked it last year--so maybe the default is unchecked? I did this a few weeks ago.
  1. Phosphates? High CYA!
    By onemsmom in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-29-2013, 04:54 PM
  2. High Phosphates
    By NelliNell in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-22-2012, 07:03 PM
  3. Advice Needed - High CYA, High Nitrates, and Lots of Algae
    By capshockeyfan in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-03-2012, 05:47 PM
  4. high level of nitrates
    By alanleafgobbler in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-07-2011, 10:32 PM
  5. At what level are nitrates too high?
    By smallpooldad in forum Dealing with Algae & Slime
    Last Post: 09-27-2006, 09:57 PM
