Hi to all. We just installed a new 33' round above ground pool (28,000 gallons) ourselves. quite a project! Unfortunately we are in a very rural area and have a very shallow well, so we were forced to pump water from a stream in our yard.
Needless to say, the water is brown as can be. I thought that I would prevent this by installing two "big blue" water filters. The first being a sediment, second being an iron reducing filter. I purchased four sediment cartridges (rated at 8000 gallons) and one iron reducer rated at 30000 gallons hoping these would be enough. Needless to say after about a foot of water in the pool they were all maxed out. Due to the expense of the cartridges, I just ran the water in unfiltered..
I have read through the metals forum here and on other sites and get some conflicting results in terms of removing the iron. It seems some say to not chlorinate before trying to remove and some say to do so. For example I know my well water system "chlorinates the water prior to filtering, I believe to make the iron "catchable" in our filtration system. This does make sense. The flip side I believe is that it creates staining??
I have added nothing to the pool yet. What should my first steps be to remove the iron?
I did read the post about the person with the sump pump and the bucket, but it just seems like that is adding another filter to speed up the process??
We have a Hayward cartidge filter with a 1.5 hp pump.
So to recap my questions are this:
Do I chlorinate before trying to filter the iron?
Does the sump pump and bucket idea just speed up the filtering process?
Or, am I better off trying to capture what I can before I chlorinate??
Being that this is stream water with a lot of bacteria how many gallons of bleach should I use to do the initial shock, when the time is right, for the 28000 gallons of water?
Thanks to all in advance.
Shane
