The handle should lock in place horizontally. This tells the aquabot which way to go when it reaches the water line. The horizontal position should be altered for each use to keep he cord from kinking up.
One possibility is that your handel has developed a leak, and is full of water. The handle is supposed to be empty and water tight, helping the robot to float. Try to shake the handle around and see if it does have water in it.
. If loss of suction is the problem, and you have already checked for obstructions, you'll need a repair center to look at it.
