Results 1 to 10 of 42
Thread: CYA in a sock
Threaded View
  1. #24
    May 2010
    Default Re: CYA in a sock
    Precursor: http://www.poolforum.com/pf2/showthr...4969#post64969
    CYA Application Experiment June 29, 2010
    Though I was fully prepared to retract my rash assessment before doing this experiment (and may still have to if my pool turns out to be 9 or 10K gallons instead of the 14K gallons I believe it is) it appears that I have been conservative in my estimation that CYA dosing shows up in testing in a few hours instead of a few days. I think preliminary testing shows that there is nearly full dissolution in less than 60 minutes.
    Procedure
    Using the Pool Calculator, 37 ounces (wt) of cyanuric acid (stabilizer) should increase CYA by 20 PPM and effect a reduction in pH of .37
    Predict CYA 50 PPM and pH 7.33
    I weighed the CYA granules on a postal scale and split into two batches, making a one gallon slurry from each and adding one right after the other into the skimmer (basket in place). Granules disappeared from both skimmer basket and pump basket in about 6 minutes. Water samples were drawn from the same location in the pool (midway between shallow and deep end) and about 18 inches from the surface. I used a 44 mL sample and 5 drops R-0004 phenol red indicator titrant for the pH test; and a 14 mL sample tube (7 mL sample and 7 mL cyanuric acid reagent) for the CYA test. All sample tubes and collectors were rinsed before testing with sample water and afterward with tap water. The CYA samples were each shaken for 20-30 seconds and titrated into a 9 mL view tube immediately. The temperature of collected sample water was 89° F . At no time was I wearing socks.
    Test Results
    BEFORE ADDITION
    pH 7.7
    CYA 30 PPM
    AFTER ADDITION
    15 minutes
    pH 7.5
    CYA 40 PPM
    30 minutes
    pH 7.4
    CYA 45 PPM
    60 minutes
    pH 7.4
    CYA 50 PPM
    120 minutes
    pH 7.4
    CYA 50 PPM
    24 hours (water temp 87° F)
    pH 7.5
    CYA 50 PPM
    48 hours (water temp 84° F)
    pH 7.6
    CYA 50 PPM
    Epilogue 7/1/2010
    In less than one hour 37 ounces of CYA added to the skimmer basket was fully testable (within the limits and precision of the titrated turbidimetric test offered by Taylor). Possible contributors to this rapid absorption: size/speed of pump; clean, oversized cartridge filter (12 PSI); high flow rate and velocity, resulting in quick turnover of pool water (< 3 hours); short run from application point to equipment pad; method of application (warm water and vigorous mixing of slurry, operation of automated pressure-side cleaner, water features, spa overflow); elevated pool water temperature (about 88-89 degrees F.) That’s all I can think of. The implications are: In small pools with warm water, great circulation and a clean filter, the CYA may break down, most of it dissolving in as little as 1/3 of the turnover time.
    Questions? Scoffs? Rebukes?
    Last edited by polyvue; 07-01-2010 at 08:07 PM. Reason: Added final test results & epilogue
    16'x29' free-form 14K gal IG gunite pool; SWCG & sodium hypochlorite 8.25%; Hayward SwimClear C4025 cartridge filter; Hayward SP3202VSP TriStar Variable Speed Pool Pump; custom test kit based on Taylor K-2006C; city; PF:8.6
  1. Pool sock question
    By samtex in forum Pool Equipment & Operations
    Last Post: 07-29-2011, 10:27 AM
  2. Skimmer Sock Full Causes Air In?
    By johndoe74 in forum Pool Equipment & Operations
    Last Post: 06-26-2006, 04:49 PM
  3. how does skimmer sock work
    By mspool in forum Dealing with Algae & Slime
    Last Post: 05-28-2006, 02:32 AM
  4. HTH Sock It
    By cschnurr in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-08-2006, 09:48 PM
