Results 1 to 10 of 10
Thread: DIY Pool Kits?
    Jul 2006
    Arkansas
    Default Re: DIY Pool Kits?
    Thanks CarlD, 9 ft would definately make me feel better than 8. Was the pool you went to a vinyl or a gunite pool, though? Doesn't that make a difference on the way the deep-end is constructed?
    Hi, a 20 X 45' would allow you to have the deeper pool and still have a 'standard' shallow end ~ 10 -12' without a hugely slanted transition slope. The deep end 'hopper' walls would probably change from the 4' standard to 6'.(again for ease of troweling the hopper walls)
    With shot concrete pools, you have a little more leeway - you don't have to make the walls fit ~ perfectly to a premade liner and the material can be shaped into whatever you want
    Quote Originally Posted by jbhogfan View Post
    The pool at that camp? It was concrete--it was long, I think probably 60' or 75' (long time ago) and at least 25' wide--it had to hold a lot of kids! It was an institutional pool. Don't ask when I was last there!
  1. HTH Test Kits
    By Barry J in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-30-2013, 02:06 PM
  2. Pool kits
    By dansdad in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-27-2013, 02:26 AM
  3. Pool water test kits or equipment
    By firemooley in forum --cleanup--
    Last Post: 11-05-2012, 05:37 PM
  4. Any experience with "pool-in-a-box" kits? Cinder blocks, pt wood, etc.?
    By Corporate Dog in forum In-Ground Pool Construction and Repair
    Last Post: 05-28-2012, 01:46 PM
  5. Pool Test Kits
    By dar0rn in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-08-2011, 08:17 PM
