Thread: Super Algae Destroyer? from Omni
    Dec 2005
    Honolulu, Hawaii.
    Default Re: Super Algae Destroyer? from Omni
    Waterbear,
    Thank you, it seems therefore this is just expensive chlorine and maybe a little too slow. So we will stick with Wal-Mart's stuff.
    Aloha.
    It's slow dissolving nature is exactly what makes it useful because it act's as a 'time release' chlorine (as does trichlor in any form). However, it does have drawbacks and should not be used on a continuous basis or if the CYA is high. It is most effective if there are only a few isolated areas of algae that need killing. If the algae is through out the pool it's easier just to 'nuke' the pool and keep the FC level high with bleach.
    Quote Originally Posted by smallpooldad View Post
    If you're using trichlor from WalMart, check your labels carefully--the WalMart trichlor around here also contains copper.
  1. Hayward Super Pump is Super Noisy
    By moneypitpool in forum In-Ground Pool Construction and Repair
    Last Post: 07-25-2011, 10:16 AM
  2. Can pool be safe with some black algae in walls if water is super clear?
    By inletyachtman in forum Dealing with Algae & Slime
    Last Post: 06-23-2011, 04:17 PM
  3. Hayward Super Pump - Super Hot and Shutting Off
    By CapitalBoo in forum Pool Equipment & Operations
    Last Post: 06-18-2011, 09:32 AM
  4. Is Super Algae 60% strength the same?
    By debs_pool in forum Dealing with Algae & Slime
    Last Post: 07-30-2007, 08:32 PM
  5. Omni Breakout 60 as Shock
    By brungardfdc in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-08-2006, 03:27 PM
