Thread: Pool looks like a swamp
    Default Pool looks like a swamp
    30k in-ground gunite
    FAC 6
    PH 7.4
    ALK 90
    CAL 200
    CYA 90
    My pool is getting worse every day. We've had about 7" of rain here in the last 2 wks. Pool store suggests super flock, let everything fall to bottom and vac. Nothing is foating in the pool. Does this make sense?
    Any help would be much appreciated.
    John
    Cool Re: Pool looks like a swamp
    jdw, while the pool store's advice would probably work - killing the algae with a sufficient dose of bleach and letting it settle to the bottom would probably also work. Ben had a 'riff' about... 'any chem you add to a pool will do something, often the desired result, but will also cause a problem that you didn't expect' -- The point is that if you just start adding 'Miracle X' chems, there will be a 'backlash' problem - POP (pool owner patience) is most often the BEST way to deal with a problem [something that took months to cause usually can't be cleared up in a day!! ]
    Default Re: Pool looks like a swamp
    Quote Originally Posted by waste View Post
    Thanks for the reply. Should I keep it at shock levels until it is completely clear?
    Ontario.
    Quote Originally Posted by jdw-tx View Post
    By saying swamp, that implies the pool is green to some extent. If you have visible algae, leave it there for sure.
    For swamp busting advice, check out this thread.
    http://www.poolforum.com/pf2/showthread.php?t=7622
    IG 32' x 16', vinyl 19,500 l, Sand filter, Hawyard Low NOx 250,000 btu heater
    Heating? Great info on why a solar cover saves $$$?
    http://energy.gov/energysaver/articl...ng-pool-covers
    Quote Originally Posted by Spensar View Post
    I would call it more cloudy than green. When I brush the pool I can see a fine light brown mist, like dirt, which I assume is some type of algae. Does this make a difference? I'm trying to keep it at 20ppm and run 24/7.
    topless is offline Registered+ Thread Analyst topless 0
    Jul 2006
    Wichita, KS
    That is a pretty good description of mustard algae.
  1. Please Help!!!! Swamp pool
    By michelle king in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-26-2012, 07:43 PM
  2. Need help shocking my swamp of a pool
    By Wolf_man in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-08-2011, 08:45 AM
  3. My pool looks like a swamp
    By vanman2501 in forum Dealing with Algae & Slime
    Last Post: 06-09-2010, 09:48 PM
  4. Swamp water pool
    By slcpunk in forum In-Ground Pool Construction and Repair
    Last Post: 05-03-2006, 03:51 PM
