Results 1 to 10 of 57
Thread: Coffee
    Mandeville, LA, USA.
    Default Re: Coffee
    Quote Originally Posted by Tominthedesert View Post
    ...Once you roast your own beans you will never go back.
    Too true. You just can't know how good coffee can be until you have some that's been made with freshly roasted beans.
    However you do need a better style coffee machine. The old Mr. coffee style drip machine will never do.
    You're right again. About the only consumer drip machine makers that make consistently great machines are Technivor and Capresso, and you've got to drop close to 200 bucks for their lower end machines.
    One of the great things about roasting your own is that you get the best possible result and save money at the same time; green coffee beans are much cheaper than roasted. Sorta like the poolforum way of maintaining your pool.
    Default Re: Coffee
    Quote Originally Posted by KurtV View Post
    The BEST coffee I ever made was in my old glass Chemex drip that you had to pour the water through after it boiled. It used heavy laboratory grade filter paper and the coffee it made was unbelievable. Haven't seen one around since the 70's. Would LOVE to find one of those again. You could even refrigerate the coffee and it would not cloud at all! It would taste fresh brewed when rewarmed slowly. The handblown ones from Germany were put into the Smithsonian because of their design.
    Default Re: Coffee
    You talking about these? Those do make great coffee. Much better than almost all auto-drip machines because the water hits the grounds at the right temperature (195F-205F) and you get the proper contact time. Most drip machines let the water get too cool by the time it hits the coffee and the water spends too long in contact with the grounds.
    Default Re: Coffee
    YES!!!!!!! I didn't know they were still being made! You used to be able to find them and the filters in just about all the department stores! Guess I will be ordering one! I gave my old one away when I couldn't find filters for it any more. The Melita filters that you find everywhere just didn't cut it! THESE ARE THE BEST COFFEE MAKERS EVER MADE. You just have to taste the coffee they produce!
