Thread: Check_In and Advice Needed
    Default Re: Check_In and Advice Needed
    Orka:
    Go with your numbers. A kid with test strips is a waste of time. Also, chlorine levels CAN change as the water sits in a jar. All you will do by questioning the validity of the store's test is alienate them. It's like trying to teach a pig to sing--you waste your time and only annoy the pig.
    Trust your Tot Alk and LEAVE IT!
    Since you have very low CYA, your FC of 3 is FINE--I don't believe you have any CC. When CYA is higher, check the Best Guess table for the ideal FC levels.
    When you raise your pH with Borax, T/A will rise too--they move together.
    Your plan on CYA is good--I suspect 4 lbs after it's dissolved in (takes 48 hours to a week) will be plenty.
    giroup01 is offline Registered+ Thread Analyst giroup01 0
    Canada
    LOL!! I have to say, English is not my primary language . . . but I love that expression!
    Reseller of Taylor water-testing products for Canada
  1. Advice on repairing pool needed..!
    By payperview in forum Above-Ground Pool Construction & Repair
    Last Post: 06-28-2011, 07:57 PM
  2. Advice Needed on Electric Cover
    By bbroglio in forum Pool Equipment & Operations
    Last Post: 09-08-2007, 05:45 AM
  3. Replacing liner; Advice needed!
    By JenniferB in forum In-Ground Pool Construction and Repair
    Last Post: 01-10-2007, 06:38 PM
  4. Major problems, advice needed...
    By Strawfoot in forum In-Ground Pool Construction and Repair
    Last Post: 12-14-2006, 02:22 PM
  5. Decking Advice Needed
    By Bearbacker in forum In-Ground Pool Construction and Repair
    Last Post: 06-15-2006, 04:25 PM
