Just a thought but does the concrete deck touch the pool at any point of its four inch thickness. Some times the concrete deck will be poured and not touch the coping but will be touching the pool bond beam below the coping. This can cause cracking problems with the coping and the tile. This would not be the cause of the heaving pool deck but the heaving and the deck touching the pool shell can. There is no problem just replacing only the brick and tile that you are having a problem with. Just an observation and not a scientific study but I have noticed more coping problems with pools that have a solid cover that covers the coping in freeze thaw areas. Hope this helps
