hey Carl
didn't you find that if the chemistry was off and the water temperature was very low, the dolphin pretty much didn't work?
hey Carl
Just return it to Costco, I did that with mine, and replace it with a Blue Pearl.
Cleancloths - why do you return yours to Costco ?
because it just started to walk a 10' path back and forth in the deep end. If I turned it off and then back on it would work for a while then go back to the deep end and just do the same thing.
No, I found they gave me that as a line why it wouldn't work. They gave me a bunch of bizarro numbers that they "required" for it to work, like super-low pH. In fact, according to the US rep's nonsense, my Dolphin should NEVER have worked. It was all BS (Barnyard Slush). Something went south.
The manuf rep in Israel didn't give me that at all. He was very cooperative.
They actually sent me a complete new (not overhauled) unit and that works. But I, in the interim, bought a Blue Diamond, and that works very well, with a few caveats:
1) I have to pull my ladder out because it gets stuck under it. It only takes 30 seconds but it shouldn't happen.
2) You cannot program it to always climb walls. You need to start it, let it run and start to move, then hit the change-direction key on the remote and it will then climb the walls every 3 or 7th time (I forgot which). It's a minor pain.
3) They rather deceptively advertise that you can use it on any shape if you have the remote. What they don't tell you is you must guide it complete for odd shapes. It only is set-and-forget for a rectangular pool, which luckily I have.
4) You have to let it sit in the water until the foam rollers soften, and leave it 20 minutes after it completes to cool.
5) Compared to the Dolphin the programming is stone-age.
OTOH,
1) the bag works just as well as the Dolphin's but is 10x easier to clean because it's a thin, single layer.
2) it cleans the pool in 1/4 to 1/3 the time.
3) it weighs far, far less
4) it always works....that's the bottom line.
BTW, you should know that all of the robotics were originally one company and the others are all split-offs, and all the units are supposedly made in Israel, or were. So they all bear a definite family resemblence.
Thanks everybody. I am going to try their customer support today and will let you know what they say. If they can not trouble shoot it, I will return it to COSTCO, but I would like to buy a replacement from COSTCO due to their generous return policy. They are currently selling the Dolphin Dynamic and the Aquabot C and the Aquabot Turbo C. Its been some time since I scoured these forums for reviews of the Aquabot products. SO I ask - what is everyones opinion of these Aquabots ? Neither seem to be remote controlled. So bottom line-- if I want to stick with COSTCO, I either give a replacement Dolphin a try or switch to the Aquabot. Thanks.
Well - it looks like I wont be speaking to customer service today. I called at 4:50pm EST and received a message that I had called after business hours of 9-5pm EST. Never mind that my manual states that customer service hours are 8:30am-5:30pm EST !!
I just ordered the aquabot turbo c from costco. Will let you know how things go. Ordered it sunday and will be here tomorow,thur. Can not wait to try it out. chris
Blding 18x36 IG vinyl rectangle with custom inpool steps, 22,000 gallons. Chris In Chapel Hill, NC us7sail@earthlink.net
Thanks- Yes please let me know how the Aquabot works for you. Is this your first purchase of a robotic cleaner ? My pool is a bit of a free-form shape, so that is a concern for me - - but nothing is perfect...
Yes this is the first robot for me. Used a baracuda that my dad has and was more a pain in the ass than anything. I want something I can throw in and forget. My wife wants me in the house with the newborn not manually cleaning the pool. I told her the robot was the only way.
