Thread: Need Opinions Fast, Hayward, Pentair, or Waterway
    Default Need Opinions Fast, Hayward, Pentair, or Waterway
    more specifically the
    Power Flo Matrix Hayward 1.5hp
    Pentair Dynamo 1.5hp
    Waterway Hi Flo 2 speed 1.5 or 2 hp
    My current setup is 2 hp Hayward with 250 pound sand filter with a 30' ag 52" walls. Im leaning toward the Waterway for the two speed feature, anyone know anything about them?
    the two main concerns are reliability and noise is a concern.
    Poughquag, New York, USA.
    Default Re: Need Opinions Fast, Hayward, Pentair, or Waterway
    Seems like you are WAY overpumped. I think you should be looking at a 1 HP 2 speed (full rated). You also need to make sure you are comparing the pumps correctly, they all need to be either FULL rated or MAX rated or you need to do the conversion before comparing.
    mjs31 is offline Registered+ Thread Analyst mjs31 0
    Texas
    Quote Originally Posted by Hightech View Post
    You may be getting to much pump. there are several sites to determine what you need. Also...you mention the waterway for the 2 speed. You can also get the Pentair Dynamo in 2 speed. I just ordered one for myself.
  1. New Hayward pump replacing old Waterway, cannot connect hoses
    By bassace1 in forum Pool Equipment & Operations
    Last Post: 10-11-2012, 12:30 AM
  2. Mix & Match Hayward/Pentair
    By bthom70 in forum Above-Ground Pool Construction & Repair
    Last Post: 03-12-2008, 11:51 AM
  3. Need help quickly. Fitting Waterway Sand to Pentair Pump?
    By mjs31 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-19-2007, 12:36 PM
  4. Hayward Pump SP2607X102S - Any opinions?
    By Ken_J in forum Pool Equipment & Operations
    Last Post: 01-15-2007, 02:58 AM
  5. Pentair vs Hayward Pumps
    By simsjim in forum Pool Equipment & Operations
    Last Post: 07-28-2006, 01:28 PM
