Thread: How much extra yard room is needed for 24' AG install?
    Default Re: How much extra yard room is needed for 24' AG install?
    Hi, you should allow about three feet extra around the pool. Plan on a thirty foot circle of level, grass free area and you will be just fine.
    Best of luck, Dennis
    mjs31 is offline Registered+ Thread Analyst mjs31 0
    Texas
    Quote Originally Posted by hrsdennis View Post
    Thanks Dennis. Unfortunately my yard is not grass free and, of course, has one of the worse for Pool liners...Bermuda. I have began killing that area, but I would guess the installers, who will also be excavating, will dig up that section? It is relatively flat so that part will not be an issue...just the grass.
    Don't assume anything, in most cases they will only do what is necessary to get a level surface, digging out problem grass is above and beyond that.
    I'd be hitting that stuff with some roundup about 2-3 weeks prior to the pool install since Roundup requires sunlight and actively growing vegetation to work.
    Mike, I agree, don’t assume. The thirty foot I was talking about was after the ground prep and installation. To keep the grass out of the pool for ever a three foot area, grass free, around the pool is needed. To keep the pool from shifting this three foot area should be at least the level of the pool before any drop offs occur.
    I was just talking about your final desired outcome, not what you have now. Discuss with the installers about removing grass and leveling ground out beyond the pool area. Also discuss ground treatment and guaranties regarding grass growth.
    Later, Dennis
    Texas
    Later, Dennis
    Thanks everyone. I am still hitting the grass with concentrated round up. I should not have said assume...I will talk with them when they stop by early next week prior to install.
  1. 1 extra slat in my wall
    By roto23 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-02-2013, 10:42 AM
  2. Extra Liner??
    By freetime in forum Above-Ground Pool Construction & Repair
    Last Post: 06-02-2013, 09:07 PM
  3. CMU true 'Olympic sized' pool and pump room
    By mavswimmer in forum Photo Gallery
    Last Post: 06-17-2012, 08:42 PM
  4. Help finding extra-large skimmer basket
    By DSCLegend in forum Pool Equipment & Operations
    Last Post: 05-28-2011, 07:56 AM
  5. Advice needed after problems arose during new liner install.
    By mtw826 in forum In-Ground Pool Construction and Repair
    Last Post: 06-17-2010, 11:45 PM
