If you provide your chemical readings you will get more constructive help on how to get your water in shape.
I had an issue a big part of the summer last year, and it started back again this year after opening.
I thought I had my water straight (looked good), but my Free Chlorine was going away faster than I could put it in. I had a bit of an algae issue that wasn't terribly visible.
Using The Best Guess CYA chart will tell you what shock level to maintain. Get it there based on your CYA level, and do your best to hold it constant until you get to where you don't lose any FC overnight. Only then will you have the algae problem whipped. You can then let your FC levels return to the proper level based on your CYA level listed on the Best Guess chart.
