The flow switch that we use is rated for 13 - 15 gpm minimum flow. Actually the specs indicate that the flow switch will deactivate at around 13 gpm, but may require 15- 19 gpm to fully activate. Having said that, it's difficult to specify what the minimum flow is other than giving you a general answer of "make sure you've got at least 20 gpm minimum".
