Would it be possible for you to post a picture? I do about 25-30 insurance reports every year for damaged above ground pools. If I could see the damage it would be easier for me to diagnose the problem. Thanks
Brad
Waterworks Pools
Brad
Waterworks Pools
Hi. Thanks for your replies! I spoke with State Farm yesterday and they told me that above ground pools are an exclusion now, grrr. I had a feeling.
A couple of weeks ago, our temps dropped to -20 with the wind chill - about -negative 8 regular temperature, and they stayed that way for almost a week. That's really the only thing different about this year as opposed to any of the other 10 years we've had the pool.
Of course, my only option is to replace the pool now, and as you might guess, I'm concerned this will happen again and I want to prevent that from happening.
Anyone have any ideas? Where did I go wrong? We lowered the water level to 6 inches below the skimmer as always. The water level in the pool is about the same except the ice formed up the sides making it look like a big bowl. I'm guessing this has something to do with the way the ice accumulated at the skimmer. Pretty bizarre looking, eh? It's all crumpled up, and punched in and bulging out, too. It only affected these couple of sections around the skimmer.
If these pics are huge let me know and I'll resize them.
See pics below
They are pretty dam huge![]()
Boyd
27' Round AG, 17,204 gallons, sand filter
Proud Father of an Army Soldier
Elle,
If you can resize the pics I'm sure those on dialup would appreciate it. Up until a few months ago I was one of those stuck with a slow connection. Anyhow...on the damage. Am I right in assuming the crinkling was just around the skimmer? I can't explain why it would happen but it looks like the water froze and was at or above skimmer level, then the water level and thus the ice block dropped and the ice chunk in the skimmer, attached to the massive ice block in the pool, pulled the skimmer and wall down. On my IG pool I routinely leave the water about halfway up the skimmer throat but I do ram a rectangular block of foam into the skimmer throat so no ice chunk protrudes into the skimmer. Your case sure doesn't look like what I would expect from ice expansion.
Sorry folks! My browser automatically resizes the pics and sometimes I can't tell how large they are when I upload them.
I reduced them all. These should be better:
http://home.comcast.net/~iamelle/DSC02804_25.jpg
http://home.comcast.net/~iamelle/DSC02796_25.jpg
http://home.comcast.net/~iamelle/DSC02789_25.jpg
http://home.comcast.net/~iamelle/DSC02782_25.jpg
http://home.comcast.net/~iamelle/DSC02777_25.jpg
Hi Poconos,
Are you in the Poconos area? I'm in the Pittsburgh area.
Anyhoo, yes, the crinkling was just around the skimmer. When we winterized, we lowered the water to 6" below the skimmer like our manual said to do, and which we always do. Whenever rain would fill it up we'd syphon off the excess. Then all this cold weather and snow came. The water was still lower but when it froze, the sides seem to have frozen first and that ice raised considerably around the sides of the pool and leaving a depression in the center. The pics show it but not so well. It's bowl shaped. I suspect that the freezing rain we had filled up the skimmer and then slowly overflowed into the pool through the skimmer. It was so cold the water probably froze down the side of the pool before it even hit the bottom water level. I think the ice in the pool and the ice in the skimmer are now linked because of that accumulation and the weight of it is pulling down the wall. Amazing what force that must be on the steel sides. How many times do people stand on the upper rails and nothing happens? Plus, we haven't had this kind of cold weather in several years, so I didn't even suspect I'd have a problem.
My problem now is that I can't drain it because it's all solid ice. I'm concerned that the wall is going to let go and a huge iceberg is going to come blowing out of there. I hope it drops straight down and doesn't slide off into the neighborhood.
You said that you pack the skimmer with Styrofoam? Is that in addition to a plug or instead of a plug? I never thought of that but it sounds like a really good way to prevent this from happening again.
Like I said, the pool is 10 years old, so I'm not too upset. I would be if it were brand new, though.I'm trying to convince my husband to replace it with an inground, lol. We're in the process of putting on a huge addition so it would be a good time.
I just saw the posting section for AB pools. I swear I looked and didn't see that yesterday. I should have posted in there.
Sorry!![]()
When you put in the pool did you get a building permit? Did you get a rider for your pool on your insurance?
If the answer is "no" to either of those that's why State Farm said it was an exclusion. If you had a building permit but no rider, S/F will probably still extend LIABILITY for damage caused by your pool, but that' s different.
That's why I tell people here to ALWAYS build according to code or their liability insurance is non-existent.
I'm going to call S/F to make sure my coverage is complete--but I did get the permits.
