Results 1 to 10 of 58
Thread: Getting Calcium Levels Right
    Parker, CO
    Default Re: Getting Calcium Levels Right
    I'll throw in my two cents for what it's worth.
    From what I was told (by chem geek), your CSI should be between -0.3 and +0.3. I try to shoot for the middle of all the recommendations on that page. For your setup I would probably go with:
    FC - 3 or 4
    pH - 7.6
    TA - 80
    CH - 300
    CYA - 40
    Assuming no SWCG and with a temp of 65 your CSI would be -.11 which the calculator will tell you the water is balanced. If your water ever got up to 100, your CSI wold be +.19 which would still be balanced. Right now with the current numbers you've input, "Corrosion of plaster is likely". If you go the other way and your CSI is +.3 or greater "Scaling is possible".
    I played with that calculator quite a bit to figure out what would be best for my spa and for the pool. Seems to be working out pretty well for me.
    Figure out what works best for you and then try to hold those numbers.
    Hope I didn't over step my boundaries. Good luck!
    36'x20' Freeform, IG - 13k gal, Spa - 800 gal, Diamond Brite, Intelliflo VS pump, TR-140C sand filter, Mastertemp 400k BTU heater, 2HP Whisperflo pump (waterfall), Pool Pilot Digital RC-42 SWCG, K-2006 Test Kit
    Virginia
    Quote Originally Posted by Toybuilder View Post
    FC - 3 or 4
    pH - 7.6
    TA - 80
    CH - 300
    CYA - 40
    I would add to be careful not to go too low on the FC. 3 is at the lowest end recommended for your CYA; it leaves no room for error. I'd shoot for mid recommended range, so about 5ppm.
    Aug 2014
    Chelsea AL
    FC - 3 or 4
    pH - 7.6
    TA - 80
    CH - 300
    CYA - 40
    I don't understand how to change the CSI though. Are you saying if I hit all the all numbers the CSI will just fall in line?
    Virginia
    Quote Originally Posted by jmarcum View Post
    CSI is calculated based on the numbers you out in. You can play around with different chem levels and you will see CSI change. For example, try the numbers Toy suggested and see how it affects the CSI number.
    Parker, CO
    Quote Originally Posted by JimK View Post
    What JimK said!
    Jul 2013
    Northern Illinois
    Great posts, guys!
    Yea, just try inputing different numbers. Like: if I raise my pH, my new CSI is ___. If I raise CH, and raise/lower pH, my CSI is ___. Play with the numbers until something makes sense for your pool.
    Jul 2013
    Northern Illinois
    Edit to above: I noticed on your screen shot that you had several variables that you were adjusting. To experiment with CSI, keep your values the same for both current and target. Only change the target on one, maybe two parameters at a time. These are the parameters that matter: pH, TA, CH, CYA, Temp, and includes any Borates and Salt.
    mas985's Avatar
    Pleasanton, CA
    The easiest thing to change is PH because it is a one for one change. Increase PH by 0.5 increases CSI by 0.5. TA and CH changes have less impact.
    Mark
  1. Calcium Hardness Levels for Heater
    By bottomcat in forum Pool Equipment & Operations
    Last Post: 06-01-2015, 08:25 AM
  2. Cloudy water in pool with high calcium levels
    By elocicero in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-09-2013, 12:39 AM
  3. Pool Calcium levels
    By beachfrontpool in forum Dealing with Alkalinity and Calcium
    Last Post: 08-22-2012, 12:39 PM
  4. Higher Calcium Levels & Stable pH
    By chem geek in forum The China Shop
    Last Post: 08-03-2008, 08:58 PM
  5. Low calcium levels, plasticizers in vinyl liners, leaching cobalt from fibergalss?
    By waterbear in forum Dealing with Alkalinity and Calcium
    Last Post: 04-21-2006, 09:07 PM
