Results 1 to 10 of 10
Thread: My Leak Story, etc.
    Jun 2013
    Central Florida
    Default Re: My Leak Story, etc.
    Check out www.leaktools.com. You can read about how leak detection works, repairs, etc. I bought my own set of tools to test my own lines. I think the high pressure broke something, maybe not right away, but jiggling the valve may have caused a "water hammer" that finished the job. If you are losing significant amounts of water, it's got to be going somewhere. If you can't see it, it's going into the ground somewhere. Good luck.
    Jul 2012
    Vegas
    Quote Originally Posted by nefretrameses View Post
    Thanks so much, I will definitely take a look at leaktools. I wish I could test my own lines, I just don't have the expertise or knowledge to do so. Yep, maybe the valve jiggling contributed and whatever had potentially been semi- damaged by the high pressure was then broken fully by water hammer. A series of unexpected bad luck problems. I agree, if I can't see the water, it's going somewhere and that somewhere has to be into the ground. I see no wet spots around the pool itself. I can only run the pump about two days, 4-5 hrs, and then it's down to the skimmer and sucking air and I have to add water. It's not a HUGE amount of water, but clearly, a leak somewhere. I'll update on what happens!
    Sep 2014
    Tucson, AZ
    Quote Originally Posted by butterflyblue View Post
    Maybe you'll get lucky and the leak will be in the skimmer (although you'd likely see wet ground around the skimmer unless it's covered by a lot of decking). Skimmers are prone to spring all sorts of leaks with age.
    Best of luck and definitely keep posting what you learn. Also post anything interesting you learn about leak detection. Posting is the best way to spread your knowledge to others....and no matter what, it's a huge help to the DIY pool community!!!
    Jul 2012
    Vegas
    As promised, I am checking back in with all of you to share the results of the leak detection on my pool. The company came out today and performed a leak detection and the good news is, there was no underground leak detected. The pressure gauge that he hooked up indicated a normal response, it held the pressure properly. So, the next step was to determine just why the pool level drops when the pump is on. Here's what he found: he noticed that the spa was in some state of disrepair with multiple tiles off in various areas. Upon further inspection, he noticed a crack in the concrete rim around the spa, where a lot of these tiles had fallen off, which he said was probably due to shifting. I, of course, had known about that crack but never put two and two together in my mind as to what connection it might have to losing water while the pump is on. I had not seen any loss of water in the spa with the pump off, so didn't feel th spa, itself was leaking. But as he explained it, when the pump is on and the water level rises in the spa, it rises to the level of that crack and the water goes out at that point, and thus causes the water loss while the pump is on.
    That made perfect sense, and I agreed with him that I could definitely see how that could happen. He putyed up the crack as best he could while here (he did a dye test and noted several areas of leakage around those same tiles), so he didn't fully repair it during this visit, but said I could probably putty up the rest of it myself, injecting silicon into the areas and also putty. The charge was $285. Yes, a bit steep perhaps, but he is a very experienced person in business since 1976, full time with pools that entire time. so I felt it was important to get someone trustworthy to look at the problem.
    So, I guess the moral of this story is: before you call a leak detection person out, make sure that any obvious signs of disrepair such as tiles falling off, areas of cracks, etc. are repaired, puttyied the best that you can. Leak detection can be expensive and you want to eliminate as much above ground as you can. Before calling him out, I had several leaks at the equipment pad fixed to eliminate those problems, but hadn't really given sufficient thought or attention to the areas he pointed out. (and hopefully fixed!) I hope my story has helped others in the same circumstances. Thanks again for this forum and all your helpful advice. I wlil always help out others if I can, also.
    Jul 2013
    Northern Illinois
    Thank you for following up! Helpful stuff.
  1. Pool store story
    By AnnaK in forum General Interest
    Last Post: 07-14-2012, 11:14 AM
  2. Another Baquacil to BBB story!!
    By amblush in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 08-02-2006, 01:36 PM
  3. Success Story!!!
    By bballdoc in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 05-25-2006, 09:55 PM
  4. Also have cloudy water (with a story)
    By Justardnck in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-19-2006, 11:45 AM
  5. A Batty Story from the PoolDoc
    By PoolDoc in forum Pools, Pets and Creepy Critters
    Last Post: 05-13-2006, 12:05 AM
