Results 1 to 10 of 24
Thread: Pool covers (solar)
    Anonymous [GDPR] European in the UK Guest
    Default Re: Pool covers (solar)
    Yes, some time difference, I heard on the UK news that a total water ban in California was it? I understand the issue, with non box/oval pools can you cut the normal cover in two to make it easier to manage? Rather do that than add the liquid cover.
    No info I am afraid, expected some from a case in the UK but the gagging order prevented it. Just to extreme for me, I want water as pure and clean as I can get and a pool cover is vital during summer, it seriously reduces chemical and water usage but I know the conditions in parts of the USA are extreme to some of our weather.
    Sep 2014
    Tucson, AZ
    Quote Originally Posted by Teapot View Post
    Luckily I live in the Copper State and not the Golden State!! Yes, Governor Brown issued an Executive Order that mandates the reduction of water use to levels 25% lower than 2013 values for all CA counties (farmers are excluded from the ban). Since the snow-pack in the Sierra Nevada mountain range is only at 5% depth of historic averages and it supplies most of CA with its fresh water, his order is reasonable. The net effect though is that most areas will have to cut back on landscape watering (unless that water is fed by grey-water systems) and folks will see higher water bills to "nudge" them to take shorter showers. Theoretically a code enforcement officer could write you a citation for washing your car in the driveway but that's probably not likely. I live in Arizona where we have lots of Colorado river water and deep aquifer wells. But AZ is almost always in a drought so we're quite use to high water bills. My landscaping is quite minimal (pretty close to Xeriscaping and artificial turf in the backyard), so my biggest water hogs are showers, toilet bowls, washing machines and.....the pool!
    Cutting up bubble covers is not really desirable for me. Aside from the irregular shape of my pool, I have two water features (a spillway from the spa into the pool and a waterfall) and that tends to sink the covers. As well, I have almost no storage area for them so they wind up gathering wildlife when rolled up (scorpions are easy to kill but scare the pants off you when you accidentally run across them). I'm tempted to try the liquid cover chemical and try to do a before and after evaporation experiment with my autofill shut off to see how much the water loss is cut down under "normal" operating procedures (the water features run at least once per day). I don't think the "gunk" load would cause a huge hit to the filter and, even if it did, tearing down the filter is a 1/2 day project anyway.
    Thanks for being a sounding board and I'll start a separate thread if/when I decide to experiment.
    Cheers!
    I see, or rather without a picture I don't Lol. adding a tow end to the cover would keep it afloat? but I wonder how you will get on with the water fall and spill over as the liquid blanket only works on still water. I wonder how the DE will get on with the coating of fats as I would think it's filtration value is in the tiny pores in the silicon, once clogged with fats, not so sure but happy for you to pop back and let us know. Because I run my system 24/7 I couldn't even if I thought it was viable idea, it wouldn't work.
    That Sierra Nevada 5% figure is quite alarming, The UK is short on reservoirs with an ever increasing population so frequent hose pipe bans over here in the summer. car washing with one of those washmatic car thingies saves a lot of water over a pressure washer etc.
    https://www.youtube.com/watch?v=hMdMcx7xhoQ
    Last edited by Anonymous [GDPR] European in the UK; 04-06-2015 at 05:09 AM. Reason: adding a link
    Sep 2014
    Tucson, AZ
    I didn't find too many links here on this forum (could be the search engine), but at TFP there are a lot of threads about liquid solar covers and COVERFree. This post of mine lists various chemicals used for this technique. They basically do work to cut down evaporation by around 80% if the air is still (compared to nearly 100% for a traditional bubble-type cover), but when there is wind or if the pump moves the water too much then their effect is reduced considerably.
    As teapot mentioned, if the film is disturbed enough to get sucked into the skimmer, it will get caught in the filter similar to what happens with suntan lotion. As for encouraging bacterial biofilm, that may be more of a problem in sand filters where channeling could occur as a result. In cartridge filters this doesn't seem to be seen as much, perhaps because chlorine is more consistently and evenly distributed in spite of such film getting caught into the filter.
    Thanks for the great insights. I can see from reading those threads and from what you all have said that I'm going to have to modify my pool operations a bit before trying the liquid cover. I have been planning on buying a Pentair valve actuator so that I can automate the 3-way valve that currently splits water between my spa and pool returns. Putting an actuator on it will allow me to run the spillway remotely and to put it on a schedule as opposed to now where it is only shut off if I go back to the equipment pad and turn the valve handle to 100% pool return (I split off about 50% of the water return to the spa).
    Between my spillway and waterfall (which only runs for 30mins two times per day), I think I have too much water agitation. Also, I'll need to redirect my eyeball returns because they tend to point slightly upwards and ripple the water. I can't do anything about the occasional light breezes we get in the afternoons so that will just have to be a given when I experiment with the liquid cover.
    Cheers!
    Apr 2015
    Las Vegas
    My new-fill water started out at 54 degrees, lots of variables, but basically with only a solar cover, it's up to 72 in a week's time. It's been warm during the days here in Vegas, but gets cool at night. Previously, it would be the end of May before I hit 72, so have to attribute a bit of that to the new solar cover.
    As for removal, not that much pain - I simply grab one corner, my son grabs another, and we fold it length-wise. Then, I have a PVC pipe that I slide under the midpoint, lift the whole thing out of the water, and hang the pipe against a side wall on the hooks where I store my skimmer poles. Easy, two minute operation, max.
  1. Solar Covers
    By malldad in forum Pool Equipment & Operations
    Last Post: 05-23-2012, 09:08 AM
  2. Solar Panels and Solar Covers
    By FlowerPool in forum Intex-type Pool Setup & Operations
    Last Post: 05-22-2012, 07:12 PM
  3. Solar covers
    By vinper in forum Pool Equipment & Operations
    Last Post: 06-24-2011, 02:20 PM
  4. Solar Covers
    By Piney in forum Pool Equipment & Operations
    Last Post: 03-28-2007, 04:18 PM
  5. Solar covers
    By hooktee in forum Pool Equipment & Operations
    Last Post: 06-21-2006, 02:11 AM
